Noisey lifter clatter.
Old Jul 1, 2024 | 06:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
Default Noisey lifter clatter.
After a spirited run on the highway, I now have a loud rocker arm. I believe I have narrowed it down to # 1 cyl Intake.
Valve-lash appears ok.
Pushrod clean, straight.
No broken spring.
Threaded rocker stud, rocker ball and nut are ok.
Valve stem, rocker movement fine.
No signs of wiped cam lobe. (Zinc oil)
Adjusting valve-lash makes no difference in clatter..
1. Question. Has anyone pulled a lifter with Intake still on? Reason I ask, just installed a new Intake last yr. Would rather take an easy route for repair
The aluminum heads have huge pushrod holes. Looks like if I remove 2 rockers, 2 pushrods, 2 rocker studs, 1 guide plate on that cyl, maybe I can fish the suspect lifter out with a magnet.
2. Question. Has anybody successfully put a new lifter in the bore that way? Would be tricky, but maybe doable.
Plan B.
Drain coolant, pull carb, pull dizzy, all 16 pushrods, put in all new lifters. And bitch the entire time doing so.
By the way, a set of flat tappet lifters are $119 - $200 todays prices. Plus, gaskets, sealant, etc. Geez oh pete.
One FT lifter is only $7
Last question: What are some of the symptoms of a lifter gone bad internally? Repairable? Toss it?
Old Jul 1, 2024 | 07:23 PM
Mdbirk's Avatar
Mdbirk
I'm going through the same thing right now! Going to check it out a little deeper Wednesday when I have time.
Old Jul 1, 2024 | 08:23 PM
HeadsU.P.'s Avatar
HeadsU.P.
It's frustrating for sure. I'd rather it happens in the Fall.
Might be a speck of dirt in the lifter orifice plunger, IDK
I can put new lifters on old cam lobes. But not vise-versa.
Old Jul 1, 2024 | 08:57 PM
augiedoggy's Avatar
augiedoggy
No broken spring.
Plan B.
from what ive seen some do come apart and can be serviced if there is debris inside. Some require less than conventional methods to do so though.
If you can get the same type/model replacement I would just replace the lifter in question since disassembly seems like more work than its worth.
I read a thread about this a couple years back were they disassembled one. it was a rather detailed thread about cam failure due to many of the newer flat tappet replacement lifters being poor quality these days with the foot not breaking in and spinning correctly and taking out lobes.
I found this video on pulling lifters apart.
Old Jul 5, 2024 | 08:47 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
S it solid or hydraulic? .... im guessing hydraulic, and if you can get a single hydraulic do it. If you blow it and loose it somewhere in the tray then you were going to take the intake off anyway. But you only have one bad so I would replace the one bad as easily as you can provide the base looks pristine on the bad one
Old Jul 5, 2024 | 04:49 PM
Bubbagum's Avatar
Bubbagum
Heads up I agree with Rescue Rogers. Less down time, almost no money out of pocket.If you open it and find a little trash in it clean it and see what happens.
Old Jul 5, 2024 | 08:22 PM
OMF's Avatar
OMF
If you have a tool like this and a spare lifter you should see what sort of maneuverability and control you can maintain to see if it's possible.
15″ Flexible Mechanical Finger, 798 | Wilde Tool
Old Jul 5, 2024 | 09:16 PM
HeadsU.P.'s Avatar
HeadsU.P.
After some thought about this, I decided to bite the bullet and buy 16 new lifters from Summit., arrived minutes ago.
Research shows that a few things can happen to induce a Hyd Flat Tappet to collapse.
1. Foreign matter inside lifter blocking the plungers ability to fill with oil / hold pressure.
This could be dirty oil, fragments of a shop towel or even a chunk of RTV that broke off of a gasket.
2. or Low oil pressure.
3. or the lifters oil galley / passage has blockage, denying oil supply to lifter.
4. Defective lifter.
Because I just swapped the Intake manifold last yr, I vote for number one cause. I must have gotten a little sloppy with RTV & shop towel.
I did find some very interesting info about new lifters. It's been said that there are basically only a couple of companies in the nation that make hyd lifters and that they supply all the cam companies.
And we all know about the past decade of lifter premature wear.
Having said that, when ordering new lifters, it seems Comp Cams has addressed this issue with a coating called Diamond Like Carbon DLC.
It helps with longevity, break-in and perhaps eliminating Flat Tappet failure. Time will tell.
Part number CCA-812D-16.
$124 for the set.
Old Jul 5, 2024 | 10:07 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
First I've heard of this coating. If it works as advertised it could be very good news for us old school engine owners.
Old Jul 6, 2024 | 10:09 AM
augiedoggy's Avatar
augiedoggy
$124 for the set.
When I researched it I found the different series of lifters being sold under different brands often came from different suppliers. For example Comp sell many different lifters from many different suppliers in different countries. Both the lifters and suppliers seem to change often. Then again Comp and their sister companies like Lunati and edelbrock likely do the same with who they source to make many of their off the shelf camshafts as well. I was told the Comp Cam I have in my car was made by Howards... The enginetech retro roller lifters im using are made by an overseas OEM lifter manufacturer. I also have a set of Comp retro roller lifters that have 13,000 miles on them that I may or may not use on my current build. They look to have noticeably more wear on the outer walls than whats in my engine now but I only have a couple thousand miles on those lifters and cam.
I know a lot of people use the Delphi stock style lifters in performance builds because of all the sourcing games played by the aftermarket suppliers.
Old Jul 6, 2024 | 10:40 AM
Bubbagum's Avatar
Bubbagum
Augiedoggy how did you like the enginetech retros?
Old Jul 6, 2024 | 10:45 AM
Bubbagum's Avatar
Bubbagum
Hey Headsup, good luck with the new lifters let us know what you find and how the new lifters work.
augiedoggy's Avatar
augiedoggy
I have had no issues with them I admit I only have a few thousand miles on them though. Im using them with a comp xr270hr and 1.6 RR. Rock auto has raised the price a bit since I bought mine for like $120 shipped for the whole set a few years back.
Old Jul 6, 2024 | 12:08 PM
Bubbagum's Avatar
Bubbagum
Thanks I remember. I went with the Howard after buying the enginetech and return them. Sort of regretted doing that. They do look the same. Still haven’t fired mine. When I do I’ll do a new post.
To Noisey lifter clatter.
