I need a recommendation of where I could buy high quality, exact reproduction fuel lines for my car. The car had SS fuel lines which I find hard to work with when it comes to leaks. I would like to get the original grade steel. I have tried both Corvette Central and CSSB but was not impressed with their fit.
I also need a fuel pump. Thank you for your recommendation.
Thanks. I checked out their website but they don't seem to have the lines from the fuel pump to 3 carbs.
After you search by year, make, model, in the left column select "Engine Lines". They are listing them as 390hp Tri-Power (should be 400/435). https://www.inlinetube.com/products/cxe6803
Thanks. I talked to Luke at CSSB Inc and he said they revised their '68 tri-power fuel lines. He is sending me a new set to try. BTW, CSSB manufactures their lines right in their shops in FL.
