Wiring help
This way you can safely upgrade everything from your Alternator to electric fans to headlight relays, fuel pumps, EFI, extra lights, modern stereo's etc. etc.
There are a couple take offs in the fuse panel that are fused and can be taped into however.
The real question is, what are you intending to add? How many amps will this draw? And do you really wish to run this through a 50 year old system?
https://www.corvetteforum.com/forums...o-8-track.html
Here's my writeup on replacing every bulb in my 80 with LEDs, including adding new backup lights.
https://www.corvetteforum.com/forums...s-learned.html
For anything you can't find at Amazon, try Waytek Wire:
https://www.waytekwire.com/
