Hi all. Took my 1981 on a small car tour in northern wyoming this past weekend. It ran great but after driving all day and then stopping to gas up, when I removed the gas cap, a ton of pressure would come out of the filler neck. Eventually, it started to leak gasoline pretty badly. I parked it and drove my truck back to colorado to get a flatbed trailer and went back up yesterday and towed it home. I assume that the tank is leaking and not a line because after the level got low enough it stopped ( car not running) but when I added 4 gallons to it it started again. ( car still not running so pump not running). I am going to replace the tank, but need to figure out why its being pressurized so much. Any help is appreciated.
Your about to pull your tank anyway so trouble shooting should be straight forward.
The tank vent line runs from the top of the tank to the left side frame rail. If the tank vent itself is fine. It runs through a rubber line to the steel line on top of the left side frame rail. Stick your head in the drivers side rear wheel well and you'll see the steel vent line on top of the frame. It goes forward to the front of the car and ends just short of the charcoal canister that is there to absorb the vapors from your fuel tank. (Early cars just used a vented gas cap.) Then another short rubber hose to the charcoal canister. The canister is then purged by the vacuum system of the engine and connected to the canister.
Any line along this route to the charcoal canister could be plugged, pinched off or the canister itself could be plugged or disconnected from the engine vacuum system so it won't purge.
Charcoal canisters can be rebuilt, new charcoal installed etc.
Or. You could just run a vented cap.
I had a similar situation many years ago, removed the gas cap and it jumped into my hand! I soon realized that because of the fumes in the garage after a drive, I had traded the vented cap for a sealed cap, which was the wrong thing to do with my system set up the (proper way) it was.........(gas odor was found to be a leaky fuel pump)
Thank you! Ive got the tank out and will examine the evaporative emissions system. When i discovered the leak i left the cap off and drove it back to the hotel, but it continued leaking as I'm afraid the tank damage was already done. Thanks again.
Well, the tank was rusted through so ordered a new one. The vapor line is plugged, I cant get compressed air through it. I ordered a replacement from summit, but may just run a vented cap as snaking that thing back there looks like quite a party.
I have the same problem with my 70 . However I’m not going to go through dropping the tank . When I get home from a drive a just under screw my gas cap let the pressure out and pull into garage . Been doing that for 3 years . Don’t open up a can of worms
My tank had to come out. It was rusted through and leaking. I would like to keep the canister system, but need to see how much fun its going to be to snake the new vapor line in. May just run a vented cap instead
Originally Posted by Dean81
My tank had to come out. It was rusted through and leaking. I would like to keep the canister system, but need to see how much fun it’s going to be to snake the new vapor line in. May just run a vented cap instead
ok didn’t know you had tank issues as well . I know to change brake lines you have to kick up the whole body ( unbelievable ) put true . I am assuming running gas lines would be the same .. ask me what I would do , I would touch any anything re installed gas tank hook all hoses and either run a vented gas cap or use my simple method of unscrewing the cap after every drive .. problem solved Good luck 👍
