corvette trasmission
Old Jul 26, 2024 | 10:14 AM
SIMONE1972's Avatar
SIMONE1972
2nd Gear
Default corvette trasmission
Hi guys . sorry for the uncertain English (I live in Italy)
I have a problem with my 1979 Corvette.
When it's hot, starting from a standstill uphill, I hear a noise on the rear differential and the traction slips. DO you know what it could be?
Old Jul 26, 2024 | 11:37 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome ...moving you here for further discussion
Old Jul 26, 2024 | 01:44 PM
MelWff's Avatar
MelWff
Change the fluid and add the GM limited slip additive.
Also check the differential side yokes for in out play.
Old Jul 26, 2024 | 10:04 PM
kkupec02's Avatar
kkupec02
Welcome
Old Jul 27, 2024 | 05:04 AM
Hardwork18's Avatar
Hardwork18
Welcome and good luck getting your issue resolved.
Old Jul 27, 2024 | 06:12 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Hello and welcome to the forum.
Please explain just a little better.
Automatic or manual transmission?
Traction slips you say? Tires slipping on the road? Transmission slipping? Clutch slipping? Rear differential making a clunking noise?
I can't hear the noise or feel the slip. Please attempt to describe better. Much more detail needed. And only when hot? Hooks up fine and no noise when cold?
Old Jul 29, 2024 | 10:51 AM
SIMONE1972's Avatar
SIMONE1972
2nd Gear
Hi.
I already add the additive, but the problem is still there.
The trasmission is automatic, tires don't slip on the road
Trasmission first slips and after an iron noise works all at ones. Only when is hot and uphill, no noise when is cold.
Old Jul 29, 2024 | 11:57 AM
MelWff's Avatar
MelWff
Find someone familiar with Corvettes. It is unclear whether you have a transmission problem or differential problem or both.
To corvette trasmission
