Radiator cap
Old Aug 1, 2024 | 07:04 PM
Mdbirk's Avatar
Mdbirk
Default Radiator cap
Went to the parts store, napa and O'Reilly's both recommend a 13lb cap but I know my 68 takes a 15lb cap. Is a 2lb difference acceptable?
Popular Reply
Aug 1, 2024, 07:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
Any time your vehicle is older than the person behind the counter,
there will be a communication issue.
Old Aug 1, 2024 | 07:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
Old Aug 1, 2024 | 08:58 PM
Mdbirk's Avatar
Mdbirk
You are completely accurate
Old Aug 2, 2024 | 04:59 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
As a official old fart. I completely agree with the above statement.
None the less. A rad cap anywhere between 13 -15 PSI will work fine.
Old Aug 2, 2024 | 07:12 AM
BKarol's Avatar
BKarol
Dewitt explains it for you, just use what the factory installed:
https://www.dewitts.com/blogs/news/1...g-should-i-use
Old Aug 2, 2024 | 07:44 AM
Uskcjk03's Avatar
Uskcjk03
Cruising
Default Radiator Cap
I don't know the operating pressure of temperature of your car but it will work but maybe not ideal. Every 1 lb. difference on your cap will have about a 3 degree effect on the boiling point, so if you went to the 13 lb. cap your coolant would boil about 6 degrees lower. If you go higher pressure your boiling point goes higher but the extra pressure is harder on your hoses. In the end I wasn't any more helpful than the parts store but at least gave you something to think about.
Old Aug 2, 2024 | 08:07 AM
Mdbirk's Avatar
Mdbirk
You know it really doesn't get over 185. Maybe 190 at a stop light. The things only ever ran hot once and that's because I didn't have a spring in the lower rad hose.
Old Aug 2, 2024 | 11:03 AM
MelWff's Avatar
MelWff
Not sure how the people you are dealing with lookup parts. The NAPA site shows two 16 lb caps not 13.
Look up the part yourself before going into the store.
https://www.napaonline.com/en/search...cap&referer=v2
Old Aug 2, 2024 | 11:05 AM
MelWff's Avatar
MelWff
O'Reilly also shows 16. Rather use 16 than 13. 15 is correct.
https://www.oreillyauto.com/detail/c...corvette?pos=0
Old Aug 2, 2024 | 11:32 AM
PJO's Avatar
PJO
Veteran: Marine Corps
Your original cap would have been 15lb cap ether an RC-15 copper/brass radiator or an RC-26 aluminum. Later RC-15 Stainless Steel cap would work for ether style radiator. You can sometimes find the stainless steel caps on ebay for $20 to $50. But the cap listed here should work.
Amazon Amazon
Old Aug 2, 2024 | 11:37 AM
Mdbirk's Avatar
Mdbirk
Took your advice, looked it up myself found the cap and part #. Went to the store.... 7.7l ? 3 carbs? What vin? 4x4? Auto or manual etc .... Came back with that 13lb cap... Told them the part number I found online..... Got it!
Old Aug 2, 2024 | 12:08 PM
MelWff's Avatar
MelWff
I know, some questions are ridiculous. I inquired about a rear transmission seal, automatic, 71 GTO and was asked if it was a diesel.
Old Aug 2, 2024 | 12:39 PM
wwiiavfan's Avatar
wwiiavfan
Old Aug 2, 2024 | 01:43 PM
BKarol's Avatar
BKarol
Curious what you are trying to accomplish with a 13psi cap rather than the recommended 15psi cap that came from the factory?
Old Aug 2, 2024 | 02:25 PM
Mdbirk's Avatar
Mdbirk
Well I'm chasing down a problem. My car spewed it's coolant on Sunday. Now the cars got a rebuilt motor, new Edelbrock water pump, new high flow thermostat. It's a 68 big block but does have an expansion tank. Last few times I've driven it it bubbles over into the expansion tank. It's at 185 degrees both on the gauge and infrared gun.... Thought I'd start by burping it.... nothing. So now my next thought is radiator cap. I bought a 15lb cap. Next I'll be doing a combustion test with this doohickey from harbor freight
Old Aug 2, 2024 | 05:17 PM
MelWff's Avatar
MelWff
Just to be clear the cap is being installed on the expansion tank? You dont have a cap on the radiator and the expansion tank?
Old Aug 2, 2024 | 05:19 PM
Mdbirk's Avatar
Mdbirk
I have a blank one the radiator and a 15lb on the expansion. Seems to have fixed my issue....I hope
To Radiator cap
