1982 Fuel Pump Relay location and testing
The ECM fuse in the battery compartment is good. I'd like to test the Fuel Pump relay, but reading various posts, it's not clear exactly where it is.
I'm told it's near the ECM in the battery compartment but I can't find it. Any help would be appreciated.
Separately, because of the fuse box location and the fuel pump fuse being way up in the corner, its hard for me to get good access with a circuit test light
to see if the slot where the fuse goes in is getting power. If it's not, what could be causing that?
Thanks in advance!
