‘76 Wiper Arm/Hood Interference
Old Aug 6, 2024 | 11:45 AM
L8T2's Avatar
L8T2
Default ‘76 Wiper Arm/Hood Interference
My ‘76 has the stock “long” hood. My problem is that the passenger side wiper arm hits the cowl part of the hood at the bottom of its arc (see photo). Does it look like the OEM arm or is it an aftermarket item with a different design? If OEM, how do I eliminate the current “interference fit”? Note that the hood sits flush with the fenders when closed.
Old Aug 6, 2024 | 04:12 PM
OMF's Avatar
OMF
I went to change my wiper blades, and had this same problem with all the sets (4) I brought home. I ended up frustrated and put the old set back on and haven't re-visited the issue.
This was the one I was looking for but couldn't find
TRICO® Exact Fit Conventional | The Best Conventional Wiper Blades (tricoproducts.com)
Old Aug 6, 2024 | 06:15 PM
gjohnson's Avatar
gjohnson
Thats not an OEM arm
Old Aug 6, 2024 | 07:42 PM
MelWff's Avatar
MelWff
Did you try NAPA?
Old Aug 6, 2024 | 07:57 PM
L8T2's Avatar
L8T2
That would probably explain the interference. Do you have a picture of the correct part?
Old Aug 6, 2024 | 08:15 PM
gjohnson's Avatar
gjohnson
Here is a OEM wiper arm off my 76
Old Aug 6, 2024 | 08:43 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome
Wiper arms are different depending on the car's year.
Check the vendor's website to get the correct year.
Trico #16-2 blades are low profile.
Old Aug 6, 2024 | 09:38 PM
OMF's Avatar
OMF
Originally Posted by MelWff
Did you try NAPA?
Yes I did, NAPA and most automotive places here in Canada aren't quite the same as in the States.....(ohh how I wish they were!!)
I guess I should start looking again now that I'm thinking about it.
Old Aug 7, 2024 | 08:46 AM
L8T2's Avatar
L8T2
Thanks for the tip about the low-profile blades. That might solve the problem without changing the arm.
Old Aug 7, 2024 | 08:54 AM
L8T2's Avatar
L8T2
Did you try NAPA?
I’ll see what they have. At a minimum, I’ll pick up some of the low-profile blades suggested by Peterbilt.
Old Aug 7, 2024 | 09:05 AM
L8T2's Avatar
L8T2
While we’re on the subject, I came across this on the Zip website:
https://www.zip-corvette.com/68-73-w...p-bracket.html
There doesn’t seem to be a similar part for the post-‘73 cars. If it fits a ‘73, it should fit the later cars too. Anyone install the bracket?
Old Aug 7, 2024 | 11:12 AM
bmotojoe's Avatar
bmotojoe
This link is the correct stop bracket for your year.
If the arm's are set correctly the blade should stop short of touching the bracket...
https://thevettecollector.com/produc...v=7516fd43adaa
Old Aug 7, 2024 | 05:33 PM
L8T2's Avatar
L8T2
It looks very different from the bracket in the Zip catalog.
To ‘76 Wiper Arm/Hood Interference
