1982 corvette crossfire wiring issue.
Old Aug 11, 2024 | 02:33 PM
crittenhouse1's Avatar
crittenhouse1
3rd Gear
Default 1982 corvette crossfire wiring issue.
I need a little help. I recently purchased a 1982 corvette the wiring is in bad shape the motor no longer has the crossfire set up but does have the ecm. My question is does the crossfire wiring at the firewall control any of the interior gauges?
Old Aug 11, 2024 | 04:51 PM
Moved to C3 Tech for some assistance.
Old Aug 11, 2024 | 05:37 PM
Fly skids up!'s Avatar
Fly skids up!
Other than the check engine light the ECM doesn't control any instrumentation. Be aware that the oil pressure sending unit wiring is part of the engine management system harness and then connects to the dash harness behind the seats.
Old Aug 11, 2024 | 05:51 PM
crittenhouse1
3rd Gear
My plan is to keep the ecm for the transmission and oil pressure sensor is there anything else I need to keep out of the harness?
Old Aug 11, 2024 | 06:19 PM
Golfobsessed's Avatar
Golfobsessed
there is other alternatives for both if that's all your using the ECM for... I used the Bowler kit for lock up but does require dropping the pan
Fly skids up!
Actually you can get rid of all of the engine management system wiring, just save the one oil pressure sending unit wire. For lock up, I've found the TransGo 700-LU works really well.
https://www.summitracing.com/parts/trg-700-lu
By using the Camaro/diesel spring in the kit it holds off 4th gear until about 45 MPH and then locks up the converter at about 47 MPH, all hydraulically without any wiring. The only catch is it only works with the earlier valve bodies which you probably have already.
Old Aug 11, 2024 | 08:24 PM
kkupec02's Avatar
kkupec02
Welcome
Old Aug 12, 2024 | 10:54 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome & GL
Old Aug 12, 2024 | 02:27 PM
ctmccloskey's Avatar
ctmccloskey
Welcome to the Corvette Forum crittenhouse1! This is the place to be when you have questions about your Corvette. The amount of experience here on this Forum is absolutely amazing and they share with anyone who has a Corvette!
That is a shame that your "New to You" Corvette has wiring issues. There are companies that make reproduction wiring harness' that are accurate and well laid out. I would use that option before making hundreds of terminations on miles of wire to fix the original harness.
With help of this Forum you should have fewer issues restoring your 1982 Corvette.
To 1982 corvette crossfire wiring issue.
