Borgeson severe leak
Old Aug 17, 2024 | 08:02 PM
Gralls4771's Avatar
Gralls4771
Default Borgeson severe leak
I installed a borgeson steering box only 3 years ago and discovered a pretty severe leak coming from the pitman shaft. When the steering hits the stops (left or right), power steering fluid literally jets out the pitman shaft seal. Has anyone else had this problem? Pain in the butt to replace?
Old Aug 17, 2024 | 08:34 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'll be watching this. No idea myself.
Old Aug 18, 2024 | 11:14 AM
Bikespace's Avatar
Bikespace
Should be no harder than installing it the first time. Have you contacted Borgeson to see if it is covered, or if they have repair parts to DIY?
There are threads on how to limit the steering fluid pressure, if that ends up being the solution.
To Borgeson severe leak
