Plug issue
Old Aug 23, 2024 | 12:50 PM
71BHG4SP's Avatar
71BHG4SP
Default Plug issue
I've only put roughly 1,800 miles on the Vette since I bought it, but figured a plug inspection might be a good idea. Seven of 'em looked pretty much perfect. The eighth looked like the pics. What causes this?
Old Aug 23, 2024 | 01:12 PM
gearheadib's Avatar
gearheadib
Burning oil.
Old Aug 23, 2024 | 01:55 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
In the first pic, it appears the insulator is chipped off. I assume you don't know how old these are.
Do they all match as far as make and part number? I'd install a new set and run it for several hundred miles and recheck them.
Old Aug 23, 2024 | 02:41 PM
pspicci's Avatar
pspicci
I would put new plugs in it and reevaluate as previous post suggests. also what cylinder did that come from? is it a cylinder that has the vac modulator hooked to it - if you have one - or anything else hooked to it that could introduce any fluids to it?
Pat
Old Aug 23, 2024 | 07:00 PM
71BHG4SP's Avatar
71BHG4SP
Originally Posted by gearheadib
Burning oil.
Argh. Not the answer I was looking for, but was kind of expecting.
They all match - Accel 376. Engine (and plugs) only has ~ 6,200 miles on it. The insulator's not chipped... must be an optical delusion. They all cleaned up like new, and they were all gapped to spec as removed, so I reinstalled them.
Pat
It was cylinder #7. All vacuum hose routing is stock... I don't believe there's anything unique about that cylinder, but please clue me in if I'm wrong.
For the record, I did not enjoy dealing with the chrome shields over the plugs on the driver's side, especially the front one ; )
Old Aug 23, 2024 | 08:15 PM
HeadsU.P.'s Avatar
HeadsU.P.
Coolant. Looks like coolant to me.
Ironically, #7 has a water-port in the head, right next to the runner.
Breeched Intake Gasket perhaps?
Old Aug 24, 2024 | 12:40 AM
71BHG4SP's Avatar
71BHG4SP
Ding! Ding! Ding! I believe we have a winner.
It didn't look like oil fouling to me, but I didn't have a more logical alternative. The intake manifold bolts - and pretty much every other bolt I've touched on this engine - were snug at best, definitely not tight. If the intake manifold gasket was breeched, however, I'm guessing I'll have to pull the manifold and replace the gaskets? It'd be great if just torquing down the manifold was the fix.
Old Aug 24, 2024 | 05:41 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'd certainly give that a go first. What do you have to loose? Retorque those intake manifold bolts. And monitor the situation. It's not at all unusual to need to retorque a intake manifold.
Old Aug 24, 2024 | 07:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
It would be impossible to find any data or stats on successful Intake Manifold installation, obviously.
But I would wager two-thirds are NOT installed correctly.
People seem reluctant to use a quality sealant, enough sealant and cover the entire gasket properly. (both sides)
Some installers insist that the Printo seal is just as good as RTV. Ah-no.
And I believe it's the only gasket on the entire engine that has to seal gas, oil, air & coolant.
It is imperative to have a 100% seal across the entire gasket or issues will crop up eventually.
To Plug issue
