Restomod wiring solutions
I’m doing a frame off restomod of my 1970 and down to planning the wiring. I’ll be changing many of the electrical components such as:
Edelbrock ProFlo and electric fuel pump
Electric fans
Relocated battery to passenger side
Upgraded and relocated alternator to passenger side
Electric headlight actuators
Electric wiper door actuator
Aftermarket gauges
Tremec TKO (back up light harness)
Aftermarket stereo
Removed air conditioning and installing aftermarket heater
Basically keeping only the keyed ignition, power windows, wipers and lighting circuits.
Given this, what direction would you go regarding a wire harness? I absolutely want to upgrade to blade type fuses. Ideally I’d keep the factory wire connectors for the circuits that will remain as well.
Dale
Very, very, very glad you suggested this! I’m at the end of the frame prep work and about ready to powdercoat. Impeccable timing!
Dale
I ran my 1/0 ground directly from the battery to the starter- then a to my alternator then to my electric fans.
And then ran a 4GA for the electronics - center of the dash/trans tunnel.
Also relocated the fuse boxes in the kick panels and used lit when blown LEDs- I highly recommend those!!!!
Oh- I have a dyno labeler- great for keeping track of your wires- even has heat shrink labels.
The Chinese stuff is a few dollars less -but look at the quality difference-and they will crap out
