Cleaning LS motors
Old Aug 30, 2024 | 02:54 PM
ignatz's Avatar
ignatz
Default Cleaning LS motors
The great thing about these is that they just don't leak, but after a decade, mine is dusty. In the old days I would go for a drive to heat the motor up, then wash it and start it right up again to dry it off.
But with all the exposed electrical on today's motor, that may be taking a big chance.
Here it is as of today. And yes it is carbureted. It looks better in this picture than in real life out in the sunshine. All the hoses could use some gloss and the valve covers and coils could benefit from something but don't know what. There's no crud, just dust and a sort of film on things that would wash right off if I was brave enough to take a hose to it. Much of the stuff that's not motor would benefit from a simple cleaner and a hosing down. I have a foaming attachment for my pressure washer.
Any tips?
Old Aug 30, 2024 | 11:07 PM
Bikespace's Avatar
Bikespace
No answers yet? You might want to ask in C5 as well.
I followed some of the ideas in this video, and had great results with some non-Corvette engines. I don't know about wire wheeling aluminum parts in the engine bay, but you can certainly remove the valve covers, clean them up, and paint them.
The #1 tip is that detailing brushes really work. Inside the car, too!
Old Aug 31, 2024 | 12:27 PM
ignatz's Avatar
ignatz
https://www.youtube.com/watch?v=PRSoRkM8GcM
Good video and lots of enthusiasm. He makes it look easier than it probably is, I am guessing this is at least an all morning job.
Wasn't much in the General corvette Topics/Car Care although I did find this:
https://www.corvetteforum.com/forums...etailiing.html
thanks for the tip on the video Joe
Old Aug 31, 2024 | 05:06 PM
71 Vert LS1's Avatar
71 Vert LS1
On my LS swaps I pretty much just spray some window cleaner on an old bath towel and start wiping it down.
All my LS swaps I have been using GM FI stuff. All engine connectors water proof.
Would I spray high pressure water at the engine? No. But I drove my 68 C10 with a LS6/4L60E swap in a massive rain storm on the freeway with zero issues.
Same with my 80 Camaro LS3/4L60E swap.
Couple of pics.
Old Aug 31, 2024 | 06:06 PM
Nikolai122's Avatar
Nikolai122
Modern engines are pretty much impervious to low pressure water, but not high pressure water. I worked in European car dealerships for roughly 30 years, and I have never heard of engine/electrical trouble from using a low pressure spray. Usually the lot lizards in the detail department use a regular low pressure garden hose to rinse the engine cleaner off when they are working underhood.
On my cars I spray a bottle of good quality engine cleaner/degreaser and let it sit for 5 minutes. Then I remove it with a spray wand in a self serve car wash. My local wash bays have 2 settings of water pressure for this purpose. The low pressure one is no more worse than a stream of rain. I towel dry and dress when done if I am feeling ambitious or going cruising. Never had a problem in, what, 40 years now ?
Whatever you do, do not hold the regular wand with high pressure even close to the "sealed" computer and fuse boxes, or wiring components, as this will be a mi$$$$$take.
Old Aug 31, 2024 | 07:38 PM
OMF's Avatar
OMF
I regularly spray the engines and engine compartments with a pressure washer. I don't get closer than 12" to anything important or to connectors. Been doing that for at least 30 yrs without one problem.....don't overthink this, they are designed to get wet.
Old Sep 1, 2024 | 10:50 AM
ignatz's Avatar
ignatz
Thanks guys. I ordered some microfiber brushes and rags and cleaner from Griots. Looking forward to an engine compartment that looks like new again.
Old Sep 3, 2024 | 12:13 PM
litevette's Avatar
litevette
I always wrap any fuse boxes, etc for protection. Tin foil works great. Easily moldable around the item and stays put. Even still, I will only use regular hose water pressure as it is plenty to wash away any degreaser, Dawn Platinum, or other stuff I may be using.
Old Sep 3, 2024 | 01:18 PM
ignatz's Avatar
ignatz
My fuze box is protected by fifty years of grease. Not going anywhere near that.
My motor is essentially naked on top so all the connectors there worry me. Even if the motor starts right up, any condensation could eventually lead to corrosion if the heat of the motor doesn't vaporize everything. So If I spray I will likely wrap all the stuff there. Big job, relatively speaking.
Old Sep 7, 2024 | 08:20 PM
litevette's Avatar
litevette
Lol! Yep, I’ve read instances of people degreasing engines, internally or externally, and leaks appearing. Sometimes that gunk is like a sealant!
To Cleaning LS motors
