Shiffty Part 2
Old Sep 12, 2024 | 08:38 AM
signify's Avatar
signify
Default Shiffty Part 2
When cold coming to a stop my 77 will not go in to gear! After a half of hour of driving smooth as butter. What could be the problem? History original clutch and all components including shifter
Old Sep 12, 2024 | 10:07 AM
Bikespace's Avatar
Bikespace
Have you tried changing your gear oil?
Old Sep 12, 2024 | 12:20 PM
signify's Avatar
signify
No and why? What kind?
Old Sep 12, 2024 | 12:46 PM
Tampa Jerry's Avatar
Tampa Jerry
Check to see if the shifter bolts are tight. There should be two of them. Also check the clutch linkage to see if you lost any of the bolts and that they are tight as well. Readjust the shifter linkage using the tool specified in the GM manual. You can always make one. While the linkage is off, see if you can move it into gear with a wrench. If it binds up or won't easily go into gear, the gear box, most likely, will have to come out. Jerry
Old Sep 12, 2024 | 12:50 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Old oil might be very thick and keeping gears from stopping rotation when it's cold and thick. Drain and refill with regular gear oil.
JIM
Old Sep 12, 2024 | 02:21 PM
Bikespace's Avatar
Bikespace
You may as well start an oil thread for all of the opinions you'll get on this.
I changed the oil in my 4-speed, and shifting improved. There is no longer a temperature dependency, it is just a clunky, external shifter at all times. But it does shift, hot and cold.
Based on my research, I used Red Line synthetic MT-90 GL-4 in my B&W Super T-10. YMMV.
Pro tip, if you do manage to pick an oil, and you have a transmission with two ports, be sure to open the top plug first. If you open the bottom port, but the top port is stuck, you'll have disabled your car.
Old Sep 12, 2024 | 06:14 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
77 is B.W. ST-10 box.
It does have a upper fill and lower drain.
I have a 77 ST-10 box myself. Yes, which gear oil is in them does make a difference.
Yes I recommend a GL4 rated gear oil.
I personally prefer a mineral based lube in these old boxes as the syncros often don't play nice with the extra slippery synthetics.
As stated above, might as well start yet another oil thread. There are as many opinions as there are members on this forum.
But bad shifting cold, perfect shifting warm certainly sounds like a thick oil problem.
Old Sep 13, 2024 | 08:08 AM
signify's Avatar
signify
Thanks! How many quarts? What is a good applicator ? Pump?
Old Sep 13, 2024 | 08:31 AM
7t9l82's Avatar
7t9l82
💯 percent agree on Red Line gear lube motor oil etc. very high quality.
Old Sep 13, 2024 | 03:24 PM
Bikespace's Avatar
Bikespace
I bought a gallon of the GL-4 I linked above. Maybe it's almost enough for two changes? Dunno.
I found a pump that screws into bottle at Amazon. Or a cheap transfer pump was $5- at Harbor Freight. Wear gloves, it's messy.
Old Sep 13, 2024 | 05:20 PM
stingr69's Avatar
stingr69
Need to verify clutch pedal free play adjustment. Your pedal needs to be able to move 1" to 1.5" at the pad with finger pressure only. You can adjust it per the assembly manual procedure. If it is hard to get in gear with the engine on but easier with the engine off, see below.
If that does not fix it you are probably due for a clutch assembly replacement.
Old Sep 13, 2024 | 06:10 PM
4-vettes's Avatar
4-vettes
holds about a quart and a half. Squeeze bottle with a hose, pump, over here in Australia you can purchase GL4 in a plastic bag with a hose. Really handy.
when I was young, poor and in a hurry I'd use a dish soap bottle with a foot of hose on it and Squeeze it in. Would have to fill the bottle several times. But it worked.
Old Sep 13, 2024 | 06:12 PM
4-vettes's Avatar
4-vettes
Oh, and if your clutch is out of adjustment, it would be out of adjustment all the time.
Old Sep 13, 2024 | 08:26 PM
wwiiavfan's Avatar
wwiiavfan
Penngrade GL-4 improved shifting in my Muncie.
Old Sep 14, 2024 | 09:24 AM
signify's Avatar
signify
Thanks! Did not think of that! Who sells mineral base or equivalent?
To Shiffty Part 2
