82 intermittent starting
Old Sep 15, 2024 | 05:37 PM
tjmullen56@yahoo.com's Avatar
6th Gear
Default 82 intermittent starting
My 82 has had intermittent starting issues everything powers on but engine doesn’t crank or click after driving then starts after setting in happened last year and I replaced the solenoid and the starter cable with the fuseable link. I also replaced the battery this year. I didn’t have a problem all year until I had the car in the shop for a different issue and they called to let me now it wouldn’t start after I had just dropped it off they checked wiring to starter and it only showed 6 volts and they could jump starter at starter connection to get to start after that it started every time so they couldn’t check out anything further. I drove it yesterday to the store came out and it wouldn’t start until I waited about an hour, shop thinks it might be starter relay interrupt
Old Sep 16, 2024 | 03:14 PM
Haggisbash's Avatar
Haggisbash
I had the same problem once and it turned out to be the electrical portion of the ignition switch (mounted on top of the steering column under the dash). The switch contacts wear over time and wouldn't make a proper connection except when cold. The switch is actuated by a rod from the key part and there is a fore-aft adjustment of the electric switch. Could also be the relay interrupt too, does it make any difference if you try to start it in neutral rather than park?
Old Sep 16, 2024 | 03:18 PM
rmrtrex's Avatar
rmrtrex
Does this happen when car has been used for a while
or when it is cold?
Old Sep 16, 2024 | 03:35 PM
6th Gear
It didn’t start in any gear even tried shifting in and out of park multiple times
Old Sep 16, 2024 | 03:36 PM
6th Gear
It seems to only happen after the car is warmed up on longer trips
Old Sep 16, 2024 | 03:37 PM
rmrtrex's Avatar
rmrtrex
Check your ignition module in the distributor or the coil. My guess is the module.
Old Sep 16, 2024 | 06:24 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Next time it happens put it in neutral.
Using your left hand to turn the key try moving the shifter slightly and see if it starts.
Did this on my 79 after years of thinking starter problem. I knew it would eventually start after about 30 minutes so so just accommodated it.
Turns out it's the neutral safety switch out of adjustment.
Someday I'll adjust it but for now it's a "theft prevention".
Old Sep 17, 2024 | 11:08 PM
klturi421's Avatar
klturi421
I second this. I had a very similar issue around this time a year ago. Couldn't figure out what it was and I threw a bunch of parts at it including ignition modules (ICM). What I found was that my distributor was stock Delco Remy (AC Delco) and had to replace the ICM with a AC Delco ICM. If I used the Standard Ignition or MasterPro ignitions from Oreilly's, the car would run for 20 minutes and then shut down. I could restart but it wouldn't run very long, maybe 2-5 minutes. If distributor is not stock you may be able to use them.
Also, going off of what you've posted so there's some details missing that would help us to further help you troubleshoot.
1. Does the engine turn over? (attempting to start)
2. If it does attempt to start, is fuel coming from the injectors? (remove air cleaner to see if it's spraying)
Some things I would check are under the distributor cap, make sure it looks good and check the rotor too.
Old Sep 19, 2024 | 05:21 PM
6th Gear
1. The engine doesn’t attempt to start no click nothing but I have power but today I took it out for a long drive amd wouldn’t start again when I got it home and while attempting to start it blew the 20 amp fuse that controls the radio interior lights and key alarm not sure if that is related
To 82 intermittent starting
