Ok, I have about given up on finding a 4L80 core to rebuild to start moving forward on my LS swap, how well will the 4l60/70 derivative hold up to long term 500-600 hp? Anyone had real luck with these units in a C3 with an LS swap? This is car I plan on driving and don't want to put in a transmission every 30-50k miles.
Massively inferior design with respect to thermal performance. You can upgrade components to handle the torque but it will always be prone to overheating by design. Whether it can me mitigated with a good cooler depends on your use case.
You can have 700r4s built for 850 hp. I had one from art carr. Never had a problem running my 427 with more power than n/a LS7 even with mods.
If I was going to do it over I would be looking at a 8 or 10 speed with some kind of traction control.
Automatic transmissions are TQ multipliers. I had severe wheel hop until I solid mounted my differential , added 500 plus pound rear mono spring, and went to dual adjustable qa1 rear shocks. Then it was just traction problems that even 345 width rear tires couldn't solve.
To make my car work again I went to a manual transmission 5 speed. If you truly have 600 hp you have to go manual unless you have power limiting traction control
Yes they can, Sonnax Beast Sun Shell, Sonnax Input Shell, Sonnax 6 pinion close ratio low gear set, 300M input shaft and your favorite shift kit will hold more than 550 to 600 , the 70 has a slightly deeper bell housing over a 60 or 65 for stronger multi clutch Lock-up unit inside the Torque Converter
I plan on LS3 install and then add forced induction down the road. so ball park was 500-600 hp. I have found a 4x4 core to build and looks like I could just install a new outputshaft, tail housing and reluctor to make it work
That's what I was researching but a ton of money to potentially shell out for it not to hold up is my concern
I have never used the Sonnax input drum myself or the 300M shaft but built many at 450 hp level with a 9 clutch conversion on 3rd clutch that would be fine at a little more power , the input drum and shaft are more turbo 1200 plus applications ...
