Starting my '78
Prior to this issue, I had rod problems, and my mechanic made the necessary repairs. Worked fine. Sometime later, I started having problems starting the car, which required me to have it towed in. He replaced the carburetor with a rebuilt one, and the day I picked it up, it fired right up. Started right up the next days as well.
However, if I don’t start the car after a few days, IT WILL NOT START. It will turn over but not fire. After a minute or two of cranking, it will begin to sputter, and with a bit of gas pedal coaxing, it will run. When I disengage the gas and press the brake to shift (Automatic), it dies (won’t hold an idle until warmed up) but then runs perfectly. The next day, it will start exactly as it should. If I let it sit for a few more days, the same problem occurs, requiring me to take it back to the mechanic to adjust.
This is a reoccurring issue—three times now. He’s adjusted the carb each time but to no avail. Neither he nor I know what is causing this issue. My unmechanical guess is that after sitting a couple of days, it is “collecting” moisture, causing it to just turn over and not fire.
Full disclosure: This is an inherited vehicle that sat for 14 years or so. I am not as mechanically involved with it as I should be, but that being said, I love my Vette and have gone to great expense to get it running. My mechanic is very competent. He services my other two vehicles and has owned a couple of Corvettes himself. Five other C3 & C4 owners (whom I know of) take their work to his shop.
Thanks for your recommendations.
Steve Holtz
Sautee, GA
Mech replaced the carb? What kind?
I suspect your fuel bowls are empty after sitting a few days.
Some Quadra Js has issues with leaks in the bottom of the bowls. Look for damp areas under the carb and sometimes manifold paint will be missing or peeling.
Just working the throttle looking in the venturi for a fuel squirt is not enough of a bowl capacity test.
Accelerator pump "wells" often have fuel, even the though the bowls are empty.
And moisture is not a concern of a "No Start" issue.
In fact, back in the day, GM introduced water into the fuel system to save gas.
Even then, that sounds like a long time for the engine to turn over before getting gas up to the carb from the fuel pump, what is your timing set to?
I converted to fuel injection about 5 years ago. In tank fuel pump. No issues whatsoever anymore. Fires straight up regardless how long it sits. Back out of the garage instantly.
You couldn't pay me to have a Automatic transmission however.
