2016 C3 of Year Finalist
Originally Posted by MelWff
So the original cloth wire according to the wiring diagram for TI would have come from the pulse amplifier and shows a resistor. How has this wire been modified to eliminate the resistor and the pulse amplifier? Diagram in link below. TI Diagram.
This could be the issue you are seeing...it could be bad, bad ground...who knows
Yes the spade is tied into the ignition switch but may be clean power. BUT
Now that I know you are tied into the old cloth covered wire those had a voltage drop when the car was started...Dont know how the light switch being an issue there but it is explicitly stated not to use those wires on an HEI distributor. The back of the ignition switch has a lot of different sources so that is why I was saying that it could be coming through the light switch. The IGN post should be a clean source from the battery or the horn relay. I havent traced it. I take it you are running your MSD under the hood in the engine compartment so try this...
This may be a solution for you. Use the Ignition wire you are currently using trigger a relay and take a direct power line off the horn relay buss bar as power for the MSD trigger through that relay. Y0u already know that is not an issue and the ignition wire voltage at the trigger side of the relay may be sufficient to keep the relay closed while you are running.
this will keep you from having to run a wire through the firewall
I am going to try this. This is a good suggestion, and I agree that the relay is not going to be as sensitive to this as the trigger wire…. So it def worth a try.
I requested a copy of the 69 wiring diagram to take a look. Meanwhile I have a 71 diagram and I suspect the ignition switch and headlight switch portion is not much different from the 71 if not identical. So Im using that diagram until I get the 69 diagram to verify but I suspect your problem is an interruption in the wire that comes from the ignition switch. The power TO the headlight switch and the ignition switch comes from the same source. If the high beam switch is malfunctioning where for that brief moment when you select high beams on then off then it would affect the same power to the ignition switch. I think your problem is not the main power to the MSD box, I think its the ign wire to the MSD that is getting interrupted for a brief moment.
To test this, (temporarily) disconnect the +12V ignition line to the MSD and run a jumper wire to the red wire that powers the MSD from the starter. Fire up the car and test the high beams and see if you get the stumble or if it goes away. At that point you will know for sure if that is what is interrupting your ignition.
I suspect the high beam switch is failing.
Im quoting myself which is a first for me? I dont know....maybe... not sure. Anyway... So you know when the ign wire to the MSD gets power from horn relay all is good. I will stand on the failed high beam switch or headlight switch. Either could be your problem but High beam switch would be my where I put my money.
Glad you found it. Bad ground problem is hard cause it looks like it's attached, but ......
I was pulling my hair out with a loose connection problem for over a year, Finally found it when running the power window caused my headlamp buckets to go down.
Bad Ground......but we need to know where the bad ground was to finish this thread.
Update. Not a bad ground. Here’s what happened.
I forgot that I was not using the original 12v source for that trigger wire.
During the same project, I got a new carb…. New carb has electric choke. I used that 12v source for the electric choke. When I hooked the MSD back up…. I used an unused wire on the ignition circuit…. The cloth covered wire. When I tested the wire to see if it had voltage (12v) only when the ignition switch was on… it did.
Unbeknown to me, that cloth covered wire is a resistor wire part of the old Transistor Ignition. As such, yes this being a resistor wire has inconsistent voltage…. Drops under 12v momentarily when turning headlights on, and also other components…
Solution…. Move the wire I used for the electric choke back to being the MSD trigger wire. Use the cloth wire for the electric choke…. Since the choke isn’t sensitive to momentary voltage changes.
OK, you're gathering information.
PLEASE, go to Mad Electrical's Web site.
Please!
I simply cannot take the time to type this much when they already have!
Please, top of their home page, tech pages. Read all about charging systems, read about headlight relays, and how and why to wire them.
I am done here. I tried.
