Ignition condenser tips
Old Oct 1, 2024 | 10:13 AM
jbakyy's Avatar
jbakyy
Default Ignition condenser tips
Hello, does anyone have any tips on ignition condenser removal and install. What a pain. I’ve already lost 1 screw that stuck to magnet and went flying somewhere. Thank you.
Old Oct 1, 2024 | 10:48 AM
sunflower 1972's Avatar
sunflower 1972
Don't remove the screw that holds the condenser bracket to distributor plate. Just loosen
the screw enough to slide the old condenser out, then slide the new condenser in. And a slotted screw holding screwdriver helps.
https://crawfordtool.com/products/ul...sd2p5013lIhwDt
Old Oct 1, 2024 | 11:40 AM
jbakyy's Avatar
jbakyy
Thank you, wish I thought about that earlier. So much easier
Old Oct 1, 2024 | 12:45 PM
sunflower 1972
Old Oct 1, 2024 | 12:48 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
AC Delco used to make what they called a "uni-set". It was a point set and condenser integrated into a single unit. It's been so long since I dealt with a "point style" ignition, so I don't know if they still sell them, but it could be worth a look.....
Old Oct 1, 2024 | 01:02 PM
sunflower 1972
Still available: https://www.napaonline.com/en/search...ion&referer=v2
Old Oct 1, 2024 | 04:02 PM
jbakyy's Avatar
jbakyy
Thanks everyone. So I’m using magnetic screwdriver then next thing I realize is screwdriver also also sticking to condenser and mini screw. Sure enough, screw goes flying of magnetic to who knows where? I’ll check the ulman, thanks everyone.
Old Oct 1, 2024 | 05:26 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by sunflower 1972
That's the one!!
Old Oct 2, 2024 | 06:00 PM
jbakyy's Avatar
jbakyy
Thanks, that’s great to know especially if the condensor screw hole gets damaged.
To Ignition condenser tips
