700R4 pressure question
Old Oct 6, 2024 | 11:23 AM
knodty's Avatar
knodty
Default 700R4 pressure question
Hi Guys,
My 74 BB has bee off the barely used over the last couple of years. I noticed last week when I took her out I found she wasn’t shifting correctly. I noticed that the TV cable connection to the carb had come off as the plastic end had split. I messed around for a while however wasn’t happy with the way the TV cable felt. I decided to test the pressure and hook it up to a gauge.
I have a Max pressure of 160psi with TV cable pulled fully out and around 70psi at idle, is this too low behind a 450hp/400lb/ft BB?
What is the best way to increase the pressure to ensure no long term damage?
Cheers
Peter
Old Oct 7, 2024 | 07:44 PM
Eric P's Avatar
Eric P
Sounds decent and I’m assuming at Idle rpm .
What is the pressure in reverse gear ?
Don’t drive it until you have a cable solution
Old Oct 9, 2024 | 01:13 PM
knodty's Avatar
knodty
Yes pressure was taken at idle, never tried it In reverse. I was just getting static readings.
I previously fitted a 2004R about 18 years ago, from BT Overdrives and that was a strong build, which had line pressure of 300psi. Not that sure with pressures on the 700R4, as I never fitted this trans.
I saw this thread the other day and was wondering if these pressures are normal for a 700 or should they be as high as my old 2004R?
https://nastyz28.com/threads/700r4-t...ssures.333308/
PS. Jim Jabroni not sure if you got my email reply?
Old Oct 10, 2024 | 09:46 AM
Eric P's Avatar
Eric P
retry the test at 1000 rpm and then at 2000 rpm and see what you have at minimum TV and at max TV , not sure what rpm your idle is at but down low below 1000 rpm is not always a good indication of what you have compared to 2000 rpm unless a pump or pressure regulator problem,
Old Oct 10, 2024 | 11:15 AM
peters220's Avatar
peters220
Did you repair or replace the cable and readjust?
Old Oct 13, 2024 | 07:27 AM
knodty's Avatar
knodty
I’m on holiday at the moment, and quickly had a look at the car before I left. Just run a pressure test with it in reverse and also drive. Didn’t take it out for a drive as I didn’t have time. Pressure at idle in Park I set at 90psi. If I slacken the TV Cable minimum pressure is 65psi, which I heard is a little too low? In Reverse at idle pressure @ 650rpm is around 170psi increasing to about 190psi holding the brake and increasing to 1500rpm. In Drive the pressure was slightly lower at 160psi and 180psi respectively. I quickly did this test over literally a couple of minutes to give you guys a rough idea of pressure. I know I need to give it a proper test drive, and see pressures at WOT and in each gear.
I did buy a new TV cable to fit as I wasn’t sure the one fitted was working properly, however after having a look at it’s operation at the moment I think it is working ok.
Peter
To 700R4 pressure question
