Diff experts please advise
Old Oct 8, 2024 | 07:00 PM
av81's Avatar
av81
Default Diff experts please advise
I have a 81 automatic car 55k miles , the car had a slight hum under acceleration then went away when you lifted, I have the diff on the bench other than minor imperfections on the pinion races I have a rod that goes through the diff with a clip on each side , it appears that the shafts on both sides were rubbing against the shaft to the point that its no good with two deep grooves worn in , the spider gears I can not spin them with a pry bar not sure if they are supposed to be that tight. Please help with advice!
Old Oct 8, 2024 | 07:06 PM
69L88's Avatar
69L88
Post some clear pics of what you have.
