I have a 78 pace car and I am seeing bubbles raising up the paint on the hood. I have a new heat shield in place. Any ideas what this is and what I can do about it? thanks!
Not thinking it's anything to do with a heat shield or heat. I've never run any kind of heat shield or hood blanket.
Blistering paint is generally poor prep work before paint now outgassing. Also oil soaking up from underneath can cause issues. A blown air conditioning compressor seal can spray oil on the underside of the hood as an example. This will soak through and create paint issues.
The joys of fibreglass!
Posting up some clear pictures of the problem could help. Or, everyone can continue to just guess.
As our Aussie member said, most likely from a bad AC seal. Where on the hood are the bubbles? If it's over the AC compressor, you have your answer. A few companies make shields to prevent this from happening. Jerry
As we all know, the small confines of a C3 engine bay certainly do not need a hood blanket to keep it warm. Nor does the hood paint need protection.
As the story goes, back in the early 70s when potential customers test drove a brand-new Vette, their lame complaint was that of: "Too Much Engine Noise".
So, the engineers sharpened their pencils and came up with a Sound Deadener.
Imagine that. A sportscar with extra noise. Not muffler. Engine noise.
So, whatever you want to call it, blanket, liner, insulation or deadener, it still contains the heat in the engine bay.
Most of them have been wisely removed over the years.
And there is a myth that the liner is to smother an engine fire. (Actually, it burns really well)
Just had mine re painted because of same issue. Few things cause it, but only if its been re painted. Most common is to repaint in modern paint without removing all the old paint. These were originally lacquer and ya cant paint over it without using lacquer. Second is bad prep work or not clean when painted and primed. Third is tarping. If the paint is under a year old and you put a tarp over it, it will bubble. Shop that re painted mine went right down to fiberglass, then used modern materials. The warranty clearly says void if tarped for any reason. Car covers permitted only in dry storage, never outside, especially if it rains.
