Fusible link questions
Old Oct 13, 2024 | 07:19 PM
Dogmark's Avatar
Dogmark
Default Fusible link questions
First why are The wire gauges and colors
idifferent on each side of the link
Second, are they all rated at the same amperage?
Thanks in advance
Old Oct 13, 2024 | 09:14 PM
bmotojoe's Avatar
bmotojoe
Thanks in advance
If you're talking about the plastic capsule, that is the splice joint between the harness and link.
As far as colors, Aftermarket link colors vary on manufacturer. It is the gauge size that is most important.
My late build 77 has its original links, both are red/orange in color and are in mm not a gauge size rating.
Old Oct 13, 2024 | 09:21 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yes, links are amp specific.
done/identified by wire gauge.
Old Oct 14, 2024 | 08:01 AM
Dogmark's Avatar
Dogmark
Sooo! 10 ga red to14ga brown to black cylindrical to 16 ga brown isn’t bubba’s handiwork? Circuit is working, but there are bare wires showing so I thought I would replace it just didn’t know what to buy! Thanks again
Old Oct 14, 2024 | 08:52 AM
bmotojoe's Avatar
bmotojoe
The specific gauge size is dependent on the load.
On my late 77 for example both #10 one from headlight circuit and the other the charge circuit use different fusible links. One is a 2.0mm (14 gauge) and the other 1.5mm (16 gauge)
Something you may want to look into before replacing.
Old Oct 14, 2024 | 01:34 PM
carriljc's Avatar
carriljc
Dogmark
fyi - a couple of infomative links:
https://whiteproducts.com/fusible-fa...ing%20a%20link.
https://www.whiteproducts.com/fusible-specs.php
and an excerpt: "
Are there any general guidelines for choosing a suitable fusible link?
Typically, a given harness segment is protected by fusible link that is four gauge numbers smaller. A 14-gauge wire would be protected by an 18-gauge fusible link. A 6-gauge wire would be protected by a 10-gauge link, and so on. Odd number wire gauge sizes like 19, 15, 13 and 11 are counted when sizing a link. The length of a fusible link should not exceed 9"."
Thanks in advance
Old Oct 14, 2024 | 03:59 PM
Dogmark's Avatar
Dogmark
OK I was just gonna cut off the link and take it to Napa to match it up, Now you brought length into the equation, probably ends where the wire changes color again? Sorry no pictures not with the car, Thank all you guys For all the info
To Fusible link questions
