Headlight/Hi Beam Issue
What am I missing? Do I need to hunt down a relay? Thanks in advance
Flow Chart to diagnose any electrical issues for your Corvette:
Corvettes—-Electrical problem—-Ground problem
My ‘71 headlamps were goofy. Cleaned connections at headlamps and the problem disappeared.
Enjoy the discoveries!
Steve O.
This is clearly the right place when you have questions regarding a Corvette! It must have bee a big change going from a C7 back to a C3! The First of the C3's was one of the coolest cars I saw while growing up. I now have a 1968 C3 convertible with a 427 L88 clone and 4 speed and a 1988 Corvette Coupe with it's L98 engine. Both great cars and yet hugely different in so many ways! Going 3 generations back must have been a tough change for you.
Without this Corvette Forum, I would be looking other places for information that I seek and it was much harder before The Corvette Forum! This forum lets you hear from people with experience that are willing to help you out and the whole system works. I learned so much here on this forum that now I feel confident to help others with their problems. It is awesome to be able to ask virtually any Corvette question and get answers from members all over the world. I know that the 1975 Corvettes are well represented here on this Forum so you are going to get the answers you seek from experienced owners.
You were able to resolve your headlight issue so you are off to a great start!
Dirty connections can plague Corvettes. I like to remove wires and clean the connections and the re secure them with battery grease to keep the oxygen out to prevent corrosion. Especially the ground wire that connects to the frame from the battery negative post. I use DeOxIt to clean my connectors now and it will remove 50+ years of corrosion off in seconds. Getting the connections clean can make the entire wiring system work better. I cleaned the light bulb sockets and the bulbs seemed to shine brighter.
At some time you might measure the voltage at the headlamp while they are on. It should be closer to full battery voltage (above 13.5 volts while driving) but since they wired the Corvettes the way they did back then you frequently find below 12 volts at the headlights under way. Having a relay would allow your lights to see battery voltage and potentially make up to 30% more light output if it is wired properly. I have done this to other cars which burn out the headlight switches and the results are amazing, 30% more light doesn't sound like much until it is dark. If you change the type of headlight to one that uses more power be sure to up-size the wires to protect your wiring harness. There are companies who make the whole harness for the headlight system but they are pricey. Speed Direct offers new halogen lights with a harness and they want a mere $968.35 for the kit. I made my harness modifications based on their design for the wiring harness.
