383 with long water pump
Old Oct 15, 2024 | 10:57 AM
Dean81's Avatar
Dean81
Default 383 with long water pump
Hi all. I have searched extensively, but only come up with answers to water pump replacement on stock C3 engines. Does anyone know if there is room for an LWP with a fan clutch in an 81 C3? Or will I be into the radiator? To clarify this is a new 383 build with new brackets and pulleys.
Thanks in advance.
Cole
Old Oct 15, 2024 | 12:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
That's not really the question, Will It Fit?
The real question is: Where will the fan blades end-up at in relation to the shroud?
Its critical the blades be about 2/3 of the way inside the shrouds outer rim.
And I don't see that happening with a Long W.P.
Old Oct 15, 2024 | 01:05 PM
Dean81's Avatar
Dean81
Thank you sir. Kind of what i figured.
Old Oct 15, 2024 | 07:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
It won't be that big of deal to swap out the Long W.P. for a "Corvette" W.P. Just more spending.
Corvette pump. Not a short W.P. There is a difference.
Then you will be assured all the pullies will should align. Depending on your brackets.
Old Oct 15, 2024 | 08:03 PM
Dean81's Avatar
Dean81
Completely understand. I was hoping to just build the motor complete with all new brackets and accessories and pull the L81 out and leave it complete on a stand. Not looking like just any old SBC will shoehorn into a C3 though, so i may look into a March Corvette kit. Thanks a ton for your help!
Old Oct 16, 2024 | 12:37 AM
Bikespace's Avatar
Bikespace
Could you just run electric fans?
A March serpentine kit costs as much as a junkyard LS conversion, but they do look pretty nifty.
Old Oct 16, 2024 | 01:06 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
don't forget corvette oil pan
To 383 with long water pump
