A/C Pressure Isssue?
Old Oct 22, 2024 | 04:11 PM
brg1's Avatar
brg1
Default A/C Pressure Isssue?
I have a 1980 Corvette with an A/C question. The new Delco A/C Compressor works great, air is about 40 degrees on an 80-degree day. However, my a/c manifold gauge will not read over 50 PSI on the high side fitting of the compressor. I swapped two compressors, a new evaporator, a condenser, and a receiver. Still shows 50 PSI or less. Help me keep my sanity. Since it works, just leave it alone. A/C Ninja is appreciated!
Old Oct 22, 2024 | 04:22 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
if low side is reading right and it cools, then high side must be "high pressure"
double check your gauges valve settings and make sure the low side isn't
bleeding into highside gauge.
I have 2 sets of gauge and hoses.
1 set physically by design doesn't allow high and low to mix.
1 set has valves to separate them.
double check your setup
Old Oct 22, 2024 | 06:07 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Must be a gauge problem.
If you are getting a 40* drop on an 80* day, it works great.
Leave it alone.
To really get an AC cold, like yours, it is the low side that you need to watch hard, and it needs to go as low as possible. Lower = colder vent temps.
Then it cycles off. Or the POA valve opens/closes.
It really needs to hit below 40# before it cuts off, ~29# is ideal. That gets your evap core down to right around 34*.
Sorry pics will not load today.
If you still have the original POA system, not a cycle switch system, they monitor evap temp and modulate the low pressure by opening or closing the orifice. Totally different system. And pressures. Keep it original as long as it works good, but the POA valves often jam up.
Then convert it to R134 & a cycle system. Almost no one will ever know and you can tune the low psi cutoff / vent temp.
Old Oct 22, 2024 | 08:20 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
If your getting 40* air at the vents then either your gauges, service port or hose is not functioning correctly. Can you take a picture of the service port and its location in the system, the high side service port should be between the compressor discharge and the orifice tube, usually after the condenser.
Where is the service port located that you are using to see the high side pressure?
Neal
Old Oct 22, 2024 | 10:46 PM
carriljc's Avatar
carriljc
brg1
I concur. If you have 40°F at the outlet vents leave it alone. You might want to spring for some new gauges though.
I would suspect faulty gauges or operator error since you have such nice cold temperatures.
Leave it alone.
Old Oct 23, 2024 | 11:45 AM
brg1's Avatar
brg1
Thanks so much and, your recommendation makes total sense. I will double-check the high-side hose and manifold and post when done.
I appreciate you!
Old Oct 23, 2024 | 11:48 AM
brg1's Avatar
brg1
Thanks so much for your help. I will follow up and post when I'm done.
Hey, Jersey Boy (Cherry Hill) over here.
I appreciate you!
Old Nov 4, 2024 | 11:47 AM
brg1's Avatar
brg1
You are an A/C Ninja. Bad higside guage. Rechecking my setup.
Thanks so much for the great suggestions!
Bernie
To A/C Pressure Isssue?
