79 headlamp actuator?
Old Feb 6, 2003 | 08:11 PM
DKBLUE79's Avatar
DKBLUE79
8th Gear
Default 79 headlamp actuator?
now that thier not frozen any more one starts to go up then drops,now what?
Old Feb 6, 2003 | 11:58 PM
gkull's Avatar
gkull
Default Re: 79 headlamp actuator? (DKBLUE79)
I was just out dorking with mine because neither would come since i moved my tranny cooler out into the nose and added a pusher fan. So I got to learn everything that i forgot 10 years ago when i had a simular problem.
The first thing which head light is it? Pop your hood open and you can reach underneath and lift up just enough so you can grap the lid and pull it up. If it sounds like compressed air when you lift up. the actuator diaphram is probably good..... I'm still using my originals.
When you tell me which one I can explain more.
Old Feb 7, 2003 | 02:07 PM
DKBLUE79's Avatar
DKBLUE79
8th Gear
Default Re: 79 headlamp actuator? (gkull)
ITS THE DRIVER SIDE LIGHT,I LIFTED AND IT SOUNDS LIKE IT IS COMPRESSING BUT CAN IT BE THAT IT JUST NEEDS TO BE GREASED,THE LIGHTS WERE UP WHEN I GOT HER,AND WHO KNOWS FOR HOW LONG? THANKS FOR YOUR HELP!
Old Feb 7, 2003 | 04:55 PM
gkull's Avatar
gkull
You probably need to raise them up and remove the bezzle. Then spray all the springs and arms down with silicone spray lube. Get all the parts working freely. When you manually lift them up. When you fire the engine the vacuum should close them with the headlight switch off.
To 79 headlamp actuator?
