Guys When removing my hard line from fuel pump up to fuel canister filter, fuel keep flowing out of the fuel line port on the pump. Does this mean I have mechanical pump is issue?? Last time I changed my hard lines I only remember fuel draining from the hard lines from the carb. Am I mistaken or do I have a problem with pump leaking fuel past a safety check valve? Sorry do know the workings of a mechanical fuel besides feeding fuel to carb based on engine operation/cam shaft rotation. v/r Mike P.
