Magnetic alignment gauge
Old Nov 20, 2024 | 06:46 PM
Golferdad's Avatar
Golferdad
Default Magnetic alignment gauge
Anybody here used the magnetic gauge digital for setting toe end or anything else as far as that goes,although I do some cheap bubble ones for $10,or digital for $50 just curious if they helped any.
Old Nov 21, 2024 | 11:58 AM
MelWff's Avatar
MelWff
Can you post a link to the tool?
Old Nov 21, 2024 | 12:05 PM
OMF's Avatar
OMF
I have one that's used to set caster and camber, and it works great, but you can't use it to set toe.
This is the type I have.....pic just grabbed from the web:
Old Nov 21, 2024 | 05:28 PM
mongoose87's Avatar
mongoose87
i used a digital angle gauge and put it on the brake disc (with the wheels on) and got it in the ball park after rebuilding a lot of my suspension. Obviously you need to have the car on the ground to do it properly.
It worked +/- 0.5 degrees.
You'll have to use something else to set toe
Old Nov 21, 2024 | 06:36 PM
Bikespace's Avatar
Bikespace
Have you read @cagotzmann's DIY alignment thread?
Pretty sure the only digits you can use to set toe are your fingers. There are plates that can attach to the wheel to get a more precise measurement.
These ones have magnets for the tape measure These ones have magnets for the tape measure
. Or you could use a
(digital) laser "tape" measure (digital) laser "tape" measure
https://www.corvetteforum.com/forums...nt-method.html
Old Nov 21, 2024 | 07:44 PM
Golferdad's Avatar
Golferdad
Thanks I will check it out.
Old Nov 26, 2024 | 06:53 PM
kanvasman's Avatar
kanvasman
Check this out, just posted today. Seems interesting to me. https://www.corvetteforum.com/forums...or-iphone.html
Old Nov 27, 2024 | 09:02 AM
JCurtiss's Avatar
JCurtiss
I use an inexpensive pair of toe plates for setting the toe on all my cars and found them to be accurate and repeatable. Keep in mind you have to use a bit of trigonometry to calculate the toe based your particular wheel size.
Jason
Old Nov 27, 2024 | 04:00 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Mines like this, works great easy to read
Old Nov 27, 2024 | 04:49 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
I never knew this tool existed.
To Magnetic alignment gauge
