Running rich/rough?
Old Nov 24, 2024 | 05:48 PM
Taijutsu's Avatar
Taijutsu
Default Running rich/rough?
My 74 w/healthy SB ran fine coming home from Dyno shop.
So it sat for a while and the smell of gas was strong.
I check my fuel line fitting and looked for any leaks, nothing.
Then checked for snug plug wires, they felt snug,
But that may have improved things, or my wistful thinking?
Now I'm wondering about a bad plug or wire?
Is it time to do the old pull plug wires until something changes?
This and the C6 seats are the big changes.
A world class 5 sp is in the works.
I have a friend at a wrecking yard.
What year mustang do I need for a donor?
TIA
R
Old Nov 24, 2024 | 07:45 PM
randallsteel's Avatar
randallsteel
running rough, as in struggling to idle? Is it fine at higher rpm?
does it sound like it has a misfire?
Give your vacuum lines a once over, a vac leak can make the engine erratic.
I personally think using a timing light is easier than pulling plug wires….maybe I’ve been bit too many times…
Old Nov 24, 2024 | 08:50 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
What is your carb?
What do the plug electrodes look like?
If you have the fuel tank vapor canister, evap hoses, and PCV valve, are they connected and properly routed?
If you open the carb's throttle plates and look below the carb, is there liquid fuel sitting on the floor of the intake?
Would you post pics of the engine without air cleaner from both sides?
Old Nov 24, 2024 | 11:01 PM
Taijutsu's Avatar
Taijutsu
The engine ran fine before I parked it.
It feels like a bad plug.
Idle is rough and slow.
I will pull wires until I find a bad cyl.
Then I can pull plug.
I did check vac, I will check harder.
Old Nov 25, 2024 | 06:26 AM
Bikespace's Avatar
Bikespace
What is your timing set to?
Old Nov 25, 2024 | 10:18 AM
MelWff's Avatar
MelWff
Exactly how long was it parked and was it inside or outside?
Old Nov 25, 2024 | 10:27 AM
Motorvation's Avatar
Motorvation
Answer to your last question: Ain’t no Mustang T-5 gonna fit. Input shaft is all wrong for Chevy. You’ll need to do some research on World Class T-5. V-6 versions don’t have optimal ratios. Camaro V-8 versions have some differences. Search: lugnutz65chevystepside on the web for an excellent primer on the WC T-5. I do remember the driveshaft needs to be 3” shorter than a stock Muncie equipt vehicle. Shifter location is way different. It’s doable. I upgraded a 65 Chevelle, but modifying was unconstrained. Or just pony up and get the TKX conversion.
Steve O.
Old Nov 25, 2024 | 11:26 AM
Taijutsu's Avatar
Taijutsu
The car was parked for over a year outside.
It was fine before I parked it.
My timing is 19* initial, 32* all in.
Old Nov 25, 2024 | 12:15 PM
MelWff's Avatar
MelWff
Gasoline could have gone bad.
Carburetor is clogged with residue from evaporated gasoline.
Rodents chewed on wires.
Water entered fuel tank due to bad seal on cap.
Drain the gasoline from tank.
Put Gumout or similar product in fresh gas.
Check all wires going to and coming from distributor.
Old Nov 25, 2024 | 01:01 PM
Taijutsu's Avatar
Taijutsu
The gas is fresh.
I checked the wires.
It feels like a bad plug?
I will pull plug wires to find the bad cyl.
Pulling the plug is a pain, but it will answer the question.
THX
R
Old Nov 25, 2024 | 01:03 PM
MelWff's Avatar
MelWff
The gas is fresh.
THX
R
You added nothing to the gas to internally remove any residue from the carburetor?
Old Nov 25, 2024 | 02:47 PM
Taijutsu's Avatar
Taijutsu
New Holly Brawler carb.
I will try gas additive.
Old Nov 25, 2024 | 03:38 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Check for a vacuum leak too.
Old Nov 26, 2024 | 12:18 PM
Taijutsu's Avatar
Taijutsu
For sure it is unburned fuel out the tailpipe!
Old Nov 26, 2024 | 01:18 PM
Bikespace's Avatar
Bikespace
Is this only happening at idle, or driving down the street?
I'm still thinking ignition! Unburned fuel in exhaust is likely due to a miss. If you don't have enough advance at idle (for example, your vac advance is plugged into ported vacuum, instead of manifold), you could have a lean miss stumble. If the exhaust isn't hot enough to ignite the fuel, you'll get the "rich" smell.
Dunno why the change, but I bet the dyno tuner didn't care about anything that happened under 3000 rpm.
Old Nov 26, 2024 | 01:41 PM
MelWff's Avatar
MelWff
Did you read that the car sat outside for over a year not started?
Old Nov 26, 2024 | 01:50 PM
Bikespace's Avatar
Bikespace
Yup! So it's probably bad gas, or varnish in the carb, or whatever. Did you read where the OP said when this was happening (idle/driving, cold/warm engine, etc.)?
Making sure the timing is set correctly takes 15 seconds, and might fix the problem. The last time my car wouldn't idle correctly, it was because I accidentally plugged the vac can into the wrong carb port.
Photos help!
To Running rich/rough?
Old Nov 29, 2024 | 03:07 PM
Taijutsu's Avatar
Taijutsu
Default Ign Testing?
I'm not real good w/elect.
I replaced rotor and cap, both were old.
After buttoning everything up carefully, NO START! WTF
I bought a replacement coil.
Before I can't return it, is there any way to test the coil?
What about the ign module?
I'm really at my wits end on this.
HELP
R
Old Nov 29, 2024 | 04:04 PM
MelWff's Avatar
MelWff
HELP
R
It ran poorly before you changed those parts?
If so, you miswired something.
Old Nov 29, 2024 | 04:35 PM
Taijutsu's Avatar
Taijutsu
There is not much to check.
I did a positive replacement for that reason.
Do coils and ign modules go out slowly or all at once?
It was getting progressivly worse!
