Snap-On 1982 C3 diagnostic machine
Old Nov 30, 2024 | 04:29 PM
OzyMark's Avatar
OzyMark
6th Gear
Default Snap-On 1982 C3 diagnostic machine
I bought a Snap-On Multi Scan diagnostic machine for ALCL (OBD1https://photos.app.goo.gl/Mqf5ojqtcKQkiJ9w6) cars from 1982-1986
I got it connected to the car today & it works but I don’t know what the paramaters are or what they should be. Has anyone ever used one of these?
it’s the same as the diag machine by MPSI.
Old Nov 30, 2024 | 05:11 PM
OzyMark's Avatar
OzyMark
6th Gear
MPSI original unit with a additional converter that I have no idea what it’s for?
Old Dec 1, 2024 | 08:45 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
https://www.corvetteactioncenter.com...codes-693.html all I could find for codes but you probably need the instruction manual. maybe contact this seller for a copy
https://www.ebay.com/itm/19327362484...Bk9SR4KRsafwZA
Old Dec 1, 2024 | 10:58 AM
MelWff's Avatar
MelWff
The Chevrolet factory shop manual should have details on diagnostics allowing you to determine what functions on that device will work.
Old Dec 1, 2024 | 12:44 PM
brushmor's Avatar
brushmor
I have found these useful for checking for things that are reading within what I would expect like the coolant sensor, map, and o2 sensor. You can use it to read codes if you don't like counting flashes. You don't really need one of these things to do these things but saves a lot of time.
Where these come in handy is when you understand the system well, things like the crossover counts, integrator, and BLM will give you an idea how well the system is working. Unfortunately, the shop manual does not go into enough detail here. I'd suggest getting a used copy of Ben Watson's book "How to Tune & Modify Chevrolet Fuel Injection".
Old Dec 1, 2024 | 02:51 PM
OzyMark's Avatar
OzyMark
6th Gear
yes I have ordered the book & waiting for delivery. 😁👍
Old Dec 3, 2024 | 11:51 AM
Eric P's Avatar
Eric P
that's not a Snap On tool scanner it's a MPSI , I have a newer version of the MPSI called a Pro Link and the old Snap On MT2500 , not sure how yours works
To Snap-On 1982 C3 diagnostic machine
