Engines
one other guestion. Has anyone took out there old block and rebuilt it and put forged steel back on it and new heads n such.. what kind of power did it push? im potentually trying to go for an engine that has nice stock power but build it up part by part getting it ready for a supercharger.
anyhelp on what should be done because i want to do it all right and i dont have to much engine experence.
thanks a million
sorry if my engine questions are starting to bug
AFR 190 heads are by far no slouch, and smog legal, so I really don't see a problem with making a decent amount of power with those. There are very few cams that are smog legal, but at the same time, there's no way for the smog check guy to check what cam you're running without tearing the engine half apart and measuring the lobes. So stay on the side of good judgement with the cam, and you'll be all right.
All other components, intake and headers, are pretty limited. There are some low/mid-rise intake manifolds that have smog provisions, and I believe 2 different long tube headers. Hedman 68301 for sure, and then some Doug Thorleys.
Exhaust will always be a problem - dual pipes with dual cats is illegal, no doubt about it. However, you can PROBABLY get by if you have a lazy tech. I've actually seen quite a few cars in California with true duals underneath the car. I was at Kragen the other day and a little old man with a 78 SA had dual cats underneath his car... and I'm for sure he didn't try to work the system.
Anyways, that's my shpiel. You probably shouldn't pay attention to me as I've been told I'm "too much of an armchair expert" by other members of a forum. Take it for what you will.
-Steve
