Water pump rebuild question
Old Dec 23, 2024 | 01:45 PM
Tuna Joe's Avatar
Tuna Joe
Default Water pump rebuild question
I’m in the process of rebuilding the water pump for my 1968 L89.
the pump, 3856284 casting number is date correct.
Id like to use my original cast iron impeller as opposed to the stamped steel that comes with most rebuild kits.
Ive read on the NCRS forum and on here that on all current rebuild kits available, the spindle diameter is different on the rebuild kits than what is OEM and trying to use the old impeller on the new spindle the tolerances are different.
So, looking for some recommendations on rebuild kits that will allow me to use my original cast iron impeller.
Any first hand knowledge of anyone that has recently rebuilt their water pumps using an original cast iron impeller.
thanks
Old Dec 24, 2024 | 11:22 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Possibly you can just re use all the original parts and just replace the Seals and Bearings. But you won't know this till you get it apart and then it will be to late.
Old Dec 24, 2024 | 03:10 PM
Tuna Joe's Avatar
Tuna Joe
2nd Gen auto parts, a seller on EBay, is selling water pump rebuild kits.
I emailed the fellow and asked about spindle diameter and he said it will be no problem using his kits and the cast iron impeller.
He claims he over sizes the spindle .02”
It arrives on Monday so I’ll report back on whether it works or not.
To Water pump rebuild question
