CAI installed on 74 LS2 swap
Old Dec 27, 2024 | 08:26 AM
corvette74's Avatar
corvette74
Default CAI installed on 74 LS2 swap
Over the holidays I had a chance to look at changing the way I installed the intake on my ls2. It was interfering with the hood support, blocking airflow and covering up the march pulley system (bling) that I installed.
So once I removed the intake I had to move the upper rad hose to allow the intake tube to drop down toward the bottom of the rad.
I used 2 75deg. elbows to get it under the rad, then a strait section through a 4" hole I drilled in the air dam to a 45deg. elbow witch put the filter up high in the nose just above the center grill opening.
Now I just need to reinstall the lower valance.
Old Dec 27, 2024 | 04:46 PM
71 Vert LS1's Avatar
71 Vert LS1
Any worries about water if caught in a rain storm? Not trying to be a smart aleck just asking.
Old Dec 27, 2024 | 04:54 PM
corvette74's Avatar
corvette74
I'm not to concerned, not a daily driver. That being said once the front plate is installed (it is removable for shows) it should deflect most of the water. If appears there is going to be a problem there are covers you can get or I could install a shield in front of the filter. I think spectre makes one that just slips under the clamp that holds the filter.
Dale
Old Dec 27, 2024 | 09:00 PM
71 Vert LS1
I know that K&N makes a pre-filter "bag" that goes over the filter to keep dust off the filter but I don't know if is helps with water.
Old Dec 27, 2024 | 09:06 PM
aerofix's Avatar
aerofix
WOW! Nice work.
Old Dec 27, 2024 | 09:33 PM
SixAddict's Avatar
SixAddict
Originally Posted by aerofix
WOW! Nice work.
very 😎
Old Feb 2, 2025 | 09:13 PM
TorchZ51's Avatar
TorchZ51
I would expect the intake temps came way down moving the filter to the front. What were your IATs before and after?
Old Feb 3, 2025 | 07:11 AM
corvette74's Avatar
corvette74
I don't know exactly what the numbers were but I was running about 225 on the temp gage. I had a few other issues, the new thermostat wasn't opening so I put the original back in. I also had the fan temps lowered to 197 on low and 205 on high. I am know running 195. I think I am getting better air flow around the engine now so that has also helped.
Old Feb 3, 2025 | 11:31 AM
kanvasman's Avatar
kanvasman
Nice way to use some wasted space. I always laughed at the CAI that people use with the filter in the engine bay. And you got bling so you might as well sho0w it off. I love it!
Old Feb 3, 2025 | 12:29 PM
corvette74's Avatar
corvette74
Thanks kanvasman, I didn't want to mention that but I didn't like covering up the march system. I can't take all the credit I built on what another forum member (riggs74) had started.
To CAI installed on 74 LS2 swap
