67 L71 intake on C3
Old Jan 16, 2025 | 04:49 PM
aaronz28's Avatar
aaronz28
Default 67 L71 intake on C3
Somewhere I think i read a 67 L71 intake is the best of the bunch but will it fit under a C3 Lt1/BB hood?
Old Jan 17, 2025 | 04:45 AM
Big Block 69's Avatar
Big Block 69
At one point, I had a 67 400hp oval port Tri-Power intake on my 69 with a stock Big Block hood.
It fit fine. I did not measure clearance. I layed the hood down gently and latched it.
It did not hit or rub anywhere.
Rick
Big Block 69
Old Jan 17, 2025 | 12:06 PM
MelWff's Avatar
MelWff
Is this an original or a reproduction?
Old Jan 17, 2025 | 12:27 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If you arent looking for originality, obviously you are not, then the oval port 68 or 69 intake will perform really well with Brodix 270 heads....I am currently running that set up with the comp cams LS6 Nostalgia cam and it runs really well but needs help for the vacuum at idle. I run a small vacuum pump to supplement the vacuum at idle
To 67 L71 intake on C3
