I have a 1968 427 Corvette that I run at the CMI track in Tamworth NH almost every weekend. I drive to and from the track but don’t use the car on the street much at all besides that. I presently run Wilwood brakes, rotor part #140-11727D and calipers part #140-11857R on the fronts. I need new front rotors and would like to change/increase the size. Wilwood offers a Narrow Superlite 6R Big Brake Front Brake kit #140-10616-R. The #140-10616-R kit includes front rotors, 6 piston calipers and pads. The #140-10616-R requires a minimum 17” wheel and is listed for a 1968 Corvette. I fit both of those requirements but need help in determining if they will fit inside my Torq Thrust wheels before making the purchase. Wilwood provides a fitment cross section diagram in their website. I am asking for help in determining if the Wilwoods will fit with my American Racing Torq Thrust wheels. I am running American Racing Torq-Thrust Classic II 18x8, 5x4.75, 4.5” backspace, 0 mm offset, 83.06 mm hub bore and .25 spacer. I believe the part # for the wheels is VN2158861. I’m only making the change to the fronts and will most likely be adding a proportioning valve.
Please advise as to whether this new rotor and caliper will fit within my front wheels. In addition, what do you recommend for a proportioning valve?
Thank you for your technical support.
Thanks for the reply. If you're referring to the proportioning valve I think that should be fairly easy to set up. I'll probably use one of the proportioning valves Wilwood offers. - Dave
Yea, the wilwood bolts right up to THEIR master cylinder.
But I'm thinking the six piston needs a 18" wheel to have proper clearance ,, but each wheel brand is different enough that you will actually need to test fit yours.
I have an 18" wheel. They call for a minimum 17". Just concerned because the actual design of the back of the wheel could make it tight... or not. I wish I could find someone on the Forum that has tried it with ARE Torq-Thrusts. If I knew for sure I'd have the order placed. - Dave
I realize this is not a vette, but I recently installed the 6 pistons on this classic build with C5 spindles, and remembered the wheels. Ill try to find what back space, ( or off set ) these wheels had when I return to the USA. But thought I'd share,,,, it can work... 🤔
