Things you recommend doing when pulling heads on a ZZ4?
Old Jan 28, 2025 | 02:28 AM
brassplyer's Avatar
brassplyer
Default Things you recommend doing when pulling heads on a ZZ4?
I'm anticipating pulling the heads off a ZZ4 350 because of a suspected head gasket problem. If I end up pulling them off assuming they aren't warped or cracked is there anything you recommend checking or doing to them since they'll be off? I believe they have under 30k miles on them.
Is there a head gasket you recommend? It has a small Weiand 142 blower on it, it sees periodic spirited street use, won't be getting flogged at the dragstrip. I believe the gaskets that are on it now are whatever Chevy put on it.
Thanks!
Old Jan 28, 2025 | 04:59 AM
randallsteel's Avatar
randallsteel
To make an accurate head gasket recommendation you need to know head chamber size, piston contribution to combustion chamber, and piston to deck measurement.
And keep an eye on final compression ratio, which is especially important with boosted motors.
example, I use 64cc heads, with 3.7cc pistons, a piston to deck of 20 thou so I used a 45 thou head gasket for a total of 65. Although quench of 45 is ideal, my motor is built for 300 shot nos at the track. Maybe I left some power on the table, maybe I didn’t, but it hasn’t blown up yet
Old Jan 28, 2025 | 07:41 AM
ctmccloskey's Avatar
ctmccloskey
When you source a new set of head gaskets try and find a set made for a "blown" engine. They made "special" head gaskets for the high compression big blocks and they have served me well. If you asked the manufacturer of the blower what they would recommend. Being a SB they should have a lot of choices for the head gaskets, finding the "right one" is the challenge.
Whenever I pull a cylinder head off of a running engine I frequently just pull both heads and then have a machine shop take them apart and verify that they are in good shape. A valve job at 30k miles is not a bad thing and shouldn't cost that much.
Did you turn the radiator on it's head and see what comes out of it yet? How about the engine block plugs?
Old Jan 28, 2025 | 02:04 PM
Fast81's Avatar
Fast81
Given your ZZ4 has stock internals, you are already at 10:1 CR so you need to REPEAT the stock gasket for your 142 blower !!!!!!!!!!
Old Jan 28, 2025 | 02:15 PM
brassplyer's Avatar
brassplyer
By "repeat the stock gasket" - do you mean replace it with a gasket that's the same as what came on it?
Old Jan 28, 2025 | 09:38 PM
Bikespace's Avatar
Bikespace
It look into MLS head gaskets (Often sold under the Cometic name, but they are OEM for Gen III and up, so there may be other manufacturers).
With a blower, a slightly thicker gasket, and slightly less compression, may be a good thing.
Old Jan 29, 2025 | 10:10 AM
Fast81's Avatar
Fast81
To Things you recommend doing when pulling heads on a ZZ4?
