All Guage Lights do not Work
Old Feb 10, 2025 | 02:54 PM
benito's Avatar
benito
Default All Guage Lights do not Work
I have checked and replaced the 5 amp fuse, I have even installed a new headlight switch that also controls the gauge lights. Still have the problem. I admit to having a hard time understanding the wiring
diagram. But I would think that it is not wired that one gauge light goes out they all do.
I caused a second problem with the installation on the new headlight switch. One of the two vacuum hoses came disconnected on both ends. One hose goes to the switch under the dash to keep the headlights raised. I need help finding were the other vacuum hose connects.
As always I appreciate any help.
Old Feb 10, 2025 | 03:38 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Make sure your tail light fuse is not blown.
Old Feb 10, 2025 | 03:41 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Depending on the year, one hose comes into the switch and the other goes to the bypass valve. What year is your car. As for the fuse, you need ot make sure you have power on both sides of the fuse. The way the power is supplied to the fuse is power comes into the headlight switch, down to the fuse then back to the headlight switch and out to the gauges also depending on the year
Old Feb 10, 2025 | 03:42 PM
benito's Avatar
benito
THANK YOU. i can read those diagrams.
Old Feb 10, 2025 | 03:50 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Not sure what year you have. The first one is for early c3 with a wiper door.
Old Feb 10, 2025 | 08:02 PM
Peterbuilt's Avatar
Peterbuilt
Do you have a good connection on the "A" pillar?
Are the vacuum hoses correct?
Old Feb 10, 2025 | 09:29 PM
benito's Avatar
benito
Thank you. I can route that vacuum hose now.
Old Feb 15, 2025 | 01:00 PM
Dagious's Avatar
Dagious
One thing is that check your ground. The bulb sockets ground to the cluster housing. To check you will need to ground the housing to the body (I clamp a wire from the cluster housing to a cross member bolt). Then “wiggle” each bulb socket to the cluster. Another potential issue is your bulb isn’t getting power from the wire inside the socket.
Hope this helps.
Old Feb 15, 2025 | 07:45 PM
benito's Avatar
benito
I think there is a ground some where. I try your suggestion. Thank you!
Old Feb 15, 2025 | 08:53 PM
carriljc's Avatar
carriljc
benito
Here are some wonderful 1969 wiring diagrams by robertea .... might as well use your year:
https://www.corvetteforum.com/forums...g-diagram.html
To All Guage Lights do not Work
