Suspension Torquing
I understand that the torque of some components shouldn't be set until the car is on the ground. The work was performed while the car was on four jackstands. The car is now on four ramps. I have the original service manual and AIM, so I can find the torque settings for each component. To help me avoid having to search through each book (because I'm lazy), can someone provide or point to a list of components I can torque now that the car is on its wheels? I imagine the sequence might be important as well.
The riding height at the front and rear are significantly higher than specs. I understand that the car will "settle down" some after riding around, but I'd like to get closer to specs before driving. The engine is full of oil and antifreeze (no hood yet). About five gallons of gasoline in the tank and about 40 pounds of extra weight sitting on the rear deck to simulate the spare tire and carrier. I will definitely take the car for a professional alignment after torques are set.
Mike
TA bolts after alignment shims installed
Rear Camber adjustment bolts
Rear shock lower nuts
Front stabilizer mount bushing bolts
Stabilizer bar link bolts
Those are all I can think of tonight, but I think that's most of them.
Not sure if order matters, but I think I'll do mine in the order listed.
What rear spring did you use? That is a common source of "unsettled appearance".
