Basic supercharging questions....
Old Feb 10, 2003 | 06:58 PM
garagedweller2's Avatar
garagedweller2
Default Basic supercharging questions....
(8-71, 6-71) what do those #s mean? Thanks!
Old Feb 10, 2003 | 07:00 PM
bence13_33's Avatar
bence13_33
Default Re: Basic supercharging questions.... (garagedweller2)
6-71 is for a 6 cylinder engine with 71 cubic inches per cylinder. So it would be for an engine with around 426 cubic inches.
8-71(what I'm going to be using) is for a 8 cylinder engine with 71 cubic inches per cylinder. So it would be for an engine with around 568 cubic inches
10-71 is for a 10 cylinder engine with 71 cubic inches per cylinder. So it would be for an engine with around 710 cubic inches.
That doesn't mean that I couldn't use a 10-71 on my motor though.
Also 8-71s originally came on Detroit Deisel motors. With the 8-71 removed form these motors they would not function at all.
[Modified by bence13_33, 6:05 PM 2/10/2003]
Old Feb 10, 2003 | 09:26 PM
garagedweller2
Default Re: Basic supercharging questions.... (bence13_33)
so an 6-71 would be ok for a 426 Hemi?
Old Feb 10, 2003 | 10:18 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
A 6-71 would probably be a good match for a fairly mild street 426. Their original diesel applications were more about low end power and those engines were pretty much all through by about 3,000 rpm. A full race 426 might use a 14-71 and spin past 9,000 rpm! Some of those big blowers take as much power to run as many of our engines make!
Schmucker's Avatar
Schmucker
No, you could use a 4-71 on an engine, it'd just have to spin faster and do more work to keep the same boost.
Old Feb 11, 2003 | 08:39 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Basic supercharging questions.... (Schmucker)
The faster a blower us spun the more heat it generates so you are bette to install a larger blower and spin it undrive or slower then take a small supercharger and overdrive it.
This said I spin my 8-71 15% overdrive to get 12 pounds of boost. The overdrive also shows up on the low speed where just normal pulling away yields about 5 psi without even trying
To Basic supercharging questions....
