1969 won’t start
Old Feb 22, 2025 | 05:28 PM
REDRAG's Avatar
REDRAG
Cruising
Default 1969 won’t start
New to posting, so sorry for any inappropriate stuff. 1969 350/350. Solid lifters n cam. Anyway, tried to start on very cold day. Turned over n stalled; not unusual for this car. Tried starting again, heard a “clunk”, then nothing. I mean nothing. Like there is no power going to the ignition. I am by no means mechanical n don’t know where to start. Has anyone run into this?
Old Feb 22, 2025 | 05:44 PM
MelWff's Avatar
MelWff
If you turn on the headlights and try to start do the lights go very dim or no change?
I assume you don't have a voltmeter?
Old Feb 23, 2025 | 04:51 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If your knowledge is limited, it's likely that you are only capable of checking the basics. Check the battery cables at the battery. Are they tight? Check the ground cable where it attaches to the frame. Basically right under the battery, you will need to get under the car to check this. I had this come loose on mine years ago. Did just like your car.
if all that is good. Check the wiring at the starter solenoid. Everything tight? And as above, lights nice and bright? If not charge battery. Do they dim when you attempt to crank the engine?
Old Feb 23, 2025 | 09:41 AM
Cam33's Avatar
Cam33
you are talking a almost 60 year old car !! Buy the AIMS manual it’s your best friend!! Be prepared to have many parts fail on these cars they were only built to least 5 years by GM . Study as much as you can, watch tube videos and try to fix everything you can yourself. If you have to take the car to a mechanic everytime you will be underwater very fast . These cars were not built like other muscle cars of the 70’s .. they were built for corporate gained because they look good.
Old Feb 23, 2025 | 11:22 AM
kansas123's Avatar
kansas123
Sounds like maybe a short somewhere that blew a fuseable link. Check the one that is very near the horn relay; it will be crusty/dry. Another is near the starter.
Old Feb 23, 2025 | 12:03 PM
REDRAG's Avatar
REDRAG
Cruising
Thank u for the tip. It is still bitterly cold here; 21 degrees. Non heated garage. Is supposed to warm up next couple of days n I will check the fuses. Thanks again.
Old Feb 23, 2025 | 12:09 PM
REDRAG's Avatar
REDRAG
Cruising
Cam33; thank u for the tips. A lot in yr response n that what I need. As soon as the weather breaks here; 21 degrees right now, I will be sure to check all that u suggest.
Old Feb 23, 2025 | 12:12 PM
633BR's Avatar
633BR
Do you have the car on a trickle charger, sounds to me like your battery is dead.
Old Feb 24, 2025 | 05:41 PM
REDRAG's Avatar
REDRAG
Cruising
633BR. Thanks for the tip, but if the battery went dead, wouldn’t I at least get a “click” when I turn the key to “start”?
Old Feb 24, 2025 | 07:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
RedRag,
Yes, usually you hear the notorious click.
But the clunk you heard might be the solenoid. It just welded itself. Bit the bullet. Headed south. Fried its internals.
Those poor solenoids do all the grunt work. Take the voltage, send the voltage to the starter, tell the Bendix to go to meet the flywheel.
All that, plus being subject to extreme heat of the exhaust. No wonder the starter will out-live three solenoids.
There is a way to test the solenoid only, by running jumper wire. Use great caution around that area when probing with "live-wires". You don't want to fry your fuses.
Solenoids are inexpensive. ($25) The better ones are heavy duty with a brown end cap. That, is ceramic to handle the heat better.
Your first dilemma is getting the front-end up on ramps, when it won't start.
If you remove any wires to the solenoid, photograph or tag the wires with masking tape & a Sharpie.
As always, disconnect the Batt before removing starter.
Good luck
Old Feb 25, 2025 | 07:23 PM
REDRAG's Avatar
REDRAG
Cruising
Originally Posted by HeadsU.P.
RedRag,
Good luck
HeadsU.P. Well, I charged the battery n got it started. Thanks for the tip. It had 34% battery life, after charging, it finally turned over. After several attempts, it did the same thing; nothing. But I tried it again n it finally started. Now I am wondering if I have some kind of short that causes a temporary disconnect. Regardless, I ran it for half n hour. I only start it every couple of weeks during the winter. Thanks again
Old Feb 25, 2025 | 07:27 PM
REDRAG's Avatar
REDRAG
Cruising
633BR. No trickle charger. Need to have n outlet put in on that side of the garage; then use a trickle. I did get it started after charging the battery. Thanks for the insight.
Old Feb 25, 2025 | 07:44 PM
REDRAG's Avatar
REDRAG
Cruising
MelWff. No lights. Charged the battery n finally got it started. Weird, but the battery showed 34% charged. Wonder if I have some kind of short that causes it to do nothing. It did it again, but I kept trying n it started.
Old Feb 25, 2025 | 08:05 PM
MelWff's Avatar
MelWff
Remove the battery in the winter, bring it inside and use a maintenance charger.
Old Feb 25, 2025 | 08:58 PM
HeadsU.P.'s Avatar
HeadsU.P.
RedRag,
You could very well have, not a short, but a Parasitic Draw of some kind.
But first, keep in mind those old-style alternators do not charge batteries rapidly. In fact, they do very little at idle and may not do any charging at really low RPMs.
Perhaps you have seen the GEN light come on below 600 RPMs.
Usually, a good half hour drive will bring the battery power up to specs.
A parasitic draw can be hidden, unknown to the driver. It could be something simple like a dome light.
Some models have a spare tire courtesy light, that may not shut off. Or rear compartment light?
Wiper relay, alarm system or a stereo CD system.
A simple test with the dome light deactivated, unhook the NEG batt cable. Put a OHM meter between the two.
Should read zero draw. (some clocks may draw a milliamp)
Just a note here on sleeping batteries.
An automotive type battery will lose 1% power per day. That's not much, right?
How about after 30 days? And 60 days? = 60%
3 months and so on.
That's why so many of us incorporate a battery maintainer.
Old Feb 25, 2025 | 09:16 PM
LowOptions's Avatar
LowOptions
Is your clock connected and working? If it is, it is draining the battery.
Take the battery out, charge it, have it load tested, clean the terminals.
Old Feb 26, 2025 | 09:55 AM
HeadsU.P.'s Avatar
HeadsU.P.
RedRag,
If you do try the Parasitic Draw test at the battery with a meter, you obviously must have the doors closed.
Or, jamb a piece of wood between the door and dome light switch.
If your meter does show some amps being drawn, start pulling fuses, one at a time, until your meter reads zero or near zero.
That fuse that stopped the draw is the culprit. Then you have to trace that circuit to find the root of the cause.
Another thing:
You could have the best ALT, best battery and no slippage fan belts on the market.
But if there is a poor GRD anywhere in the charging system, the battery will not self-charge.
A perfect charging circuit has perfect grounds too.
To 1969 won’t start
