Advice needed. Somehow snapped my strut rod bracket.
Anyway, here's how it looks :
I've already ordered a replacement bracket. It's on the way. I have a couple questions about the swap that hopefully some of you might have some wisdoms to help with...
Will it be extra difficult to remove the strut rod from the severed portion of the bracket? If so, what tools can I have at the ready to limit that extra difficulty?
Also, what other parts need to go in with this bracket? I understand that it houses some bushings where the struts enter it. So there's that. Anything else?
Thank you all in advance!
I would be concerned about the condition of the threads in the differential housing. I have never seen anything like this type of failure.
as mentioned above, did the bolts shear off in the diff housing? If the sheared bolts can be easily removed that’s one thing, but if they are stuck or the threads are ruined….. well If it was me I would not try any drilling/tapping with the diff in the car, I’d remove it and do the work on a bench.
Really curious how this happened? Did you hit a massive pothole or something?
And I definitely didn't romp any potholes or run over any road debris. This had to have been a pre existing condition. I was making a right turn at about 7 mph. Heard the snap and immediately pulled it over and checked it out. Luckily I was close enough to turn around and get it back on the driveway.
Anyway, I didn't realize I needed to completely remove both strud rods to put a new bracket on... Gotta replace the castle nuts and pins once I take those off the shock mount I believe... Ran out of daylight
Gonna finish it another day this week if I can.
