Heater box diaphragm.
Old Mar 9, 2025 | 02:19 PM
ETRADIO's Avatar
ETRADIO
Default Heater box diaphragm.
I tested all my diaphragms around the heater box…. And of course, the only one that’s losing pressure is the one that’s behind the box to the left. Is there a way to change that out without removing the entire heater box?
or is it OK if it slowly loses pressure? I tested it with a pressure gun and the vacuum and it’s the only one that slowly leaks down. It may be just fine as long as the car is running cause I have constant vacuum. I just don’t know if that’s the way it’s supposed to be or not. Does anyone here know the answer to this question?
thank you.
