72 base 350 opinions
Old Mar 25, 2025 | 11:22 PM
kansas123's Avatar
kansas123
ttt
Old Mar 26, 2025 | 09:24 AM
Eric P's Avatar
Eric P
I bet the Performer makes over a 150 Ft lbs of torque over the Torker at 1650 rpm stall speed of your torque converter, Intake manifold alone would make the car feel twice as powerful from a dead stop compared to the Torker
Old Mar 27, 2025 | 08:52 AM
7t9l82's Avatar
7t9l82
Originally Posted by 67:72
How do you have the timing set?
Follow the recommendations to obtain ~36° of mechanical advance at ~3000rpm. What this accomplishes is maximum timing in the most desired RPM band — the idle timing just falls where it falls. Then look at what specs your vacuum advance has, when it comes on and max vacuum and how that compares to your engine vacuum ("2-inch rule").
For a lot of folks this difference in the way timing is set makes a noticeable difference in the seat of the pants feel.
Right track, do this first, you don't know how the engine is built.
Old Mar 30, 2025 | 10:37 AM
Cam33's Avatar
Cam33
72 base 200hp was the beginning and the end of the faster engines. Please don’t tell me it was rated in net hp rather than gross hp . It was just as slow than the 73-82
Old Mar 30, 2025 | 01:32 PM
7t9l82's Avatar
7t9l82
Well, the L-82 cars with the distributor along with a good exhaust would run right around 14 flat in a quarter mile. That was right around what many of the so called muscle cars ran. So don't be too harsh.
Old Apr 1, 2025 | 10:18 AM
Cam33's Avatar
Cam33
Originally Posted by 7T1vette
'72 engine is nearly the same as the '71 engine. Only difference was the rating system used: SAE gross vs. SAE net. The lowering of the CR in '71 (and later) made a significant difference in power output...but it wasn't as "drastic" as most folks spout.
I dyno a low mileage 72 base . Didn’t break 200 HP everyone that says that never actually had it dyno . If they all did they would be surprised
Old Apr 1, 2025 | 10:43 AM
7t9l82's Avatar
7t9l82
A base 350 is. Not in the same league as an LT-1 under any conditions. But rebuilding a decked LT-1 with a stroker crank etc it's not an LT-1 any longer.
Old Apr 1, 2025 | 10:52 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
And an L48 can perform just as well as that L82, or better, with the bolt-on mods mentioned above, for not a lot of money.
That's what I call the sweet spot, for money in vs HP out.
It does not even matter much if you start with an L48 or a L82, very much.
You just get a few more HP quicker with the L82.
Once you get to the end of that bolt-on list they are about the same.
And will run pretty close to an original LT-1.
A ~330HP L48/L82 is pretty strong and a lot of fun.
That should get you into the 13s and over 100 mph.
The new heads make a big difference.
If you want a lot of performance, for not too much extra money, a new 383 build is a very sweet choice, and would be my next step.
But more performance than bolt-on starts to really get expensive.
Once you get past that bolt-on stage, you have to get into short blocks, cubic inches, drivetrain, IRS, and rubber, to up your game.
You can just spend money everywhere, on everything.
Sure it will be faster, but there is always someone around with a bigger stick.
I saw so many guys play that HP game for decades, it is like a bottomless pit.......just trying to fill it with money.....
Old Apr 1, 2025 | 11:30 AM
Piersonpie's Avatar
Piersonpie
The car or the engine? I would imagine a 1975 with its huge catalytic converter and even worse timing specs would be slower than a 1972.
Old Apr 1, 2025 | 12:39 PM
OldCarBum's Avatar
OldCarBum
The thing is, nobody ever street raced their Corvettes.
We all had muscle cars back in the 60’s and 70’s, street raced and went to the drags.
You never saw anyone with Corvettes out on the streets or at the drags.
Once or twice over the years, but most guys had Corvettes for daily drivers and weekend cruisers, so raw horse power didn’t matter a single bit.
They were more in the luxury sports car class and that’s how they were driven.
Old Apr 2, 2025 | 01:56 PM
Cam33's Avatar
Cam33
yes it would bit with a couple of add ons not that expensive will blow away the gutless 72 200 low compression sewing machine engine
