Massive but temporary vacuum leak?
Old Mar 11, 2025 | 07:42 PM
Dave Culp's Avatar
Dave Culp
Default Massive but temporary vacuum leak?
I took the dash out of my 73 to replace the speedo and tach, and while I was in there I replaced the kickdown switch. After things were mostly back together I went around the block a few times to warm it up, then got on it to check the kickdown. The kickdown worked fine (first time since I bought the car). I got the revs up to about 3600 rpm and backed down, so not a harsh test. After that the engine ran real rough and I lost brake boost. I limped home, then next day started her up and she ran normal. I've since driven about 30 miles to car shows and haven't had any issues, although I haven't tested the kickdown since. Any ideas what this could be?
