Big Block 1/2 Shaft Torque Spec
Old Feb 11, 2003 | 11:44 AM
69L71's Avatar
69L71
Default Big Block 1/2 Shaft Torque Spec
My AIM lists the torque for installing 1/2 shafts to the pumpkin for a SB with the whimpy U-bolts and not the BB with bolts and saddles. I know I'm probably not looking in all the right places, but I haven't found the proper torque anywhere. I'm assuming it's in the 50 ft-lb range.
Anyonehave it handy?
Old Feb 11, 2003 | 12:06 PM
Marks69BB's Avatar
Marks69BB
Default Re: Big Block 1/2 Shaft Torque Spec (69L71)
In my 69 AIM, it is 40-50 ft-lbs and is located on page 377 in the optional equipment section at the beginning of the BB engines under the L36 option on sheet B7. Good luck! :cheers:
Old Feb 11, 2003 | 03:57 PM
dman535's Avatar
dman535
Default Re: Big Block 1/2 Shaft Torque Spec (Marks69BB)
Tighten it till it strips...then back it off a quarter turn.. ;)
Old Feb 11, 2003 | 09:50 PM
Denmech's Avatar
Denmech
Default Re: Big Block 1/2 Shaft Torque Spec (dman535)
:party: :iagree: :party:
Old Feb 11, 2003 | 10:37 PM
71DropTop's Avatar
71DropTop
:lolg: :lolg: :lolg: so true
To Big Block 1/2 Shaft Torque Spec
