headers
Old Mar 15, 2025 | 07:02 PM
pappy6062's Avatar
pappy6062
Default headers
Looking for best fitting stainless steel ceramic coated headers 1973 L82 w/pwr str & ac. Then exhaust and muffler. - Suggestions?
Old Mar 15, 2025 | 07:32 PM
Fly skids up!'s Avatar
Fly skids up!
I have these: https://pertronixbrands.com/products...eramic-coating
They fit good, clear everything and they actually have more ground clearance than the stock y-pipe.
Old Mar 15, 2025 | 07:57 PM
pappy6062's Avatar
pappy6062
thanks for the quick get back - Happy motoring!
Old Mar 16, 2025 | 11:31 AM
ctmccloskey's Avatar
ctmccloskey
I have been using a set of Hedmann headers on my 427 and they fit perfectly without any modifications with a hammer. I had a set for a 1970 LT1 engine and they also fit like a glove despite only having P.S., P.B.. They slid right into place and worked like a charm.
Ceramic coatings are a kind of tricky thing. If your engine is already running and in the car then you have no problem. The people who make the ceramic coatings will void the warranty on a set of pipes with ceramic coatings used on a new engine that is yet to be broken in. The extra friction/heat that you get while breaking in a new engine can cause excessive temperatures that can damage the coatings.
I use high compression in my 427 and the coatings burned off the first 3-5" on each tube because of the higher temperatures that the extra compression makes. I was told to order a bare set, fit them and then send them off to get them coated in a Higher Temperature rated ceramic coating. The NASCAR guys run higher compression than I do and their exhaust systems have to look good for the pictures. I was told that it would be between $200 and $300 to simply coat the new headers and 10 days turn-around. (Before COVID).
I would wait and see the responses from people with the same year and engine as you do. That would be the most accurate way to find what works. I am partial to Hedmann because of my prior experience with them and how long they have lasted on the Corvettes.
Old Mar 16, 2025 | 03:41 PM
randallsteel's Avatar
randallsteel
I used summit racing brand, easy fit up, however they require a mini starter, which a lot of us have anyways
Old Mar 16, 2025 | 04:58 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
I am running Stan's Tri-Y ceramic coated on my 79 L82. He's no longer in business but I thought I read somewhere that one of his employees purchased all his jigs and was continuing on but I can't find anything. Quality is absolutely perfect. Maybe somebody has an update?
Old Mar 16, 2025 | 06:12 PM
60 SHARK's Avatar
60 SHARK
I may have been misinformed but am woundering why you want both stainless AND coated headers.
School me on this. I was of the mind, eather one or the other, not both..
Old Mar 16, 2025 | 11:44 PM
Silver 7T8's Avatar
Silver 7T8
C3 (Also C2) STAN’S Tri-Y Headers are supposedly still available from >>
Bruce Reed
4515 S 362nd St, Auburn, WA 98001
United States, Washington
BREWSCUSTOMS@GMAIL.COM
Also See Bruce’s Face Book Page ?
Old Mar 17, 2025 | 07:53 AM
Capt. Shark
Bruce Reed
Old Mar 17, 2025 | 02:22 PM
pappy6062's Avatar
pappy6062
Default stainless
Stainless for long lasting durability & ceramic coating for heat protection from engine. would also replace exhaust with Stainless tubing.
Old Mar 17, 2025 | 02:33 PM
MelWff's Avatar
MelWff
Sounds good in theory but have you actually found that combo. In most cases ceramic coated headers are not stainless.
Old Mar 17, 2025 | 07:40 PM
pappy6062's Avatar
pappy6062
Hedman's manufactures 304 stainless steel and ceramic coated headers for 350 corvettes. although they are more $, the benefits seem worth the $.
To headers
