Curious AFR results
The carb is the original (17057203) with 77 jets and what I think are 52 rods. The rods measure 0.052" at the 'top' of the taper, but closer to 0.047" at the 'bottom' of the taper, just before it steps down to 0.026". I had the secondaries locked out, but those rods are CH.
Also, I installed the oxygen sensor at the end and on top of the 3" header collector, just before the first flanged connection.
So, at idle it ran around 12 or 13:1. I ran the idle screws in a 1/4 turn twice with not much effect. On the road at 40 mph and light cruising throttle the reading was way up around 18 or 19:1. Give it part throttle to speed up, and it would drop to 17 or so, but not to 15. During the 300-ft runs at WOT, it dropped to 11.8 or 12. Also curious is that it did not hunt or surge at cruising, as I would expect from such a lean condition. It actually runs great across the board. BTW, 300-ft times were ~5.5 seconds. Pitiful, I know, but it was just primaries.
Blipping the throttle in the garage it seems pretty responsive, but I tried Lars' test that disconnects the accelerator pump arm while running, and it stumbled noticeably, backing up what the meter says about the lean condition.
So, having read and re-read the papers, the 77's seem ok for WOT, but for the lean cruising I can go to a skinnier rod, or play with the power piston height. My question is, does raising the stop on the power piston get the cruising location of the rod up to a point where the jet is seeing the narrow (0.047") part of the rod? And is that enough to get the AFR down around 15:1?
Appreciate any feedback.
It sounds like your jetting is correct on the primary side for WOT operation, and on idle side as well (mine runs best at 12:1 = less stinky.) Just getting that mid range richer will help throughout the power band.
It will be interesting to see how the AFR readings change once the secondaries open up.
Anyway, it's close enough for now, since I'll have to do this again after the next step - tear it apart and install aluminum heads and a cam!
Once you open the secondaries, the numbers should come in line.
I sleep in until 07:00, then ease my way through the mornings.
Summer is right around the corner, so I’ll need to change my routine to get things done outside before the heat settles in.
My days of working outside in the sun when it’s in the upper 90’s are over.
Retirement is great! 😊
