Rubbing Half shafts
Old Apr 20, 2025 | 02:49 AM
76_StIngr@y's Avatar
76_StIngr@y
3rd Gear
Default Rubbing Half shafts
Replaced trialing arms, bearings, routers switched out shocks for coilovers and new strut rods. It's all been aligned but now the outer ends of my half shafts rub the back end of the flanges. Any idea why?
Old Apr 20, 2025 | 03:05 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Is this happening when your suspension is hanging? If so, that's normal. Put a floor jack under the shock mount stud and raise the trailing arm to at least near normal ride height position. Now check.
You should never spin those half shafts with the trailing arms hanging.
