Bad Fuel Pressure Gauge
Old Apr 20, 2025 | 01:24 PM
Bloodzone's Avatar
Bloodzone
Default Bad Fuel Pressure Gauge
I can hear air being sucked in at a fuel pressure gauge mounted just before the fuel rail going into a Holley.
Its through the gauge because I can put pressure on it with my hand and it stops. I'm not leaking fuel. I have a new one ordered.
Question is: Could this cause a high idle? At low speeds (stop and go traffic) my idle will go up to around 1400. I can stab the gas and it will drop but will go up again after a red light or 2.
Old Apr 20, 2025 | 01:57 PM
MelWff's Avatar
MelWff
No, will not cause high idle. On a warm engine that is running open throttle by hand to see if you can duplicate the issue. Assume your choke is fully open .
